  New Posts New Posts RSS Feed: over inflated tires
Topic Closedover inflated tires
Direct Link To This Post Topic: over inflated tires
    Posted: 01 May 2017 at 7:35am
Originally posted by Happy Tripping
I tried a search with the miserable 'search' function - no results, so ...
I recently went to my friendly neighborhood rv store, asked them to grease the bearings and inflate the Class C tires (I know - lazy, but it sure was convenient) for the coming year.
After my first trip I checked the tires (I know, I should have done it daily- this had better teach me) and the pressure was around 65 psi.
From the internet, tires can be safely over inflated, maybe it's even good in certain situations, but I feel pretty obviously this is too high by far (Class D level).
Comments on over inflating tires??
You should be set at 50psi. The 65 psi won't harm anything over the course of a single trip. Over time, you will see excessive wear in the center of the tread. Just drop it back to 50psi, and camp on..  ;)
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 01 May 2017 at 5:08am
 Always put your trailer tires at maximum cold inflation pressure, whatever the side wall says. If it says 50 psi, do it.
When towing, it's also a good idea to inflate the rear tow vehicle tires +5 psi over the recommended cold tire pressure. This helps with stability.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
osage View Drop Down
Direct Link To This Post Posted: 30 Apr 2017 at 10:03pm
ok, be sure to check your tires when they are cold. as you drive and the tires get hot the pressure will rise
so if they are 50psi when cold they may go up 10psi when hot  someone correct me if I'm wrong which I am 90% of the time
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 30 Apr 2017 at 8:55pm
For reasons I can't recall right now, I keep the tires on my pod at 50#.  Pretty sure they're C rated and they call for 50# on the sidewall.  In my opinion airing them up to 65# is probably okay but not good for any reason I can think of.  I wouldn't want to run them at that pressure for any length of time; it would probably eventually cause premature wear in the middle of the tread.  Short term, it's unlikely there is any harm done.
Happy Tripping View Drop Down
Direct Link To This Post Posted: 30 Apr 2017 at 7:50pm
