  New Posts New Posts RSS Feed: Tongue Weight
Topic ClosedTongue Weight
Direct Link To This Post Topic: Tongue Weight
    Posted: 21 Jan 2010 at 7:36am
    My main concern was the tongue weight. Going to a class 3 hitch was able to increase the tongue weight capacity. We have the V6 3,500 LB. tow capacity, the class 2 hitch would have been fine with that but with the 300 Lb. tongue weight capacity of the class 2 , I wanted more to be safe. With trailer fully loaded at times we may be near 3,000 LBs. With the rule 10 % of trailer weight should be on the tongue we will feel safer with the class 3. Does anyone need a class 2 hitch for a saturn vue or chevrolet equinox Smile .    David and Danette
2014 Ram 1500 Quad cab
Direct Link To This Post Posted: 21 Jan 2010 at 10:15am
The class 3 will at least give you the ability to go up to your vehicle's 350 lbs max tongue weight, so it wasn't a bad purchase.  Try the tongue-down configuration before you add a sway bar, if you can easily swap your tow bar around or borrow someone else's.  Mine can either go 2" up or 2" down by flipping it (and then moving the ball), which in my case took me from slightly tongue-up to slightly down.  No sway bar necessary.
rpodcamper.com View Drop Down
Direct Link To This Post Posted: 21 Jan 2010 at 2:09pm
I'm towing a 171 and started with a jeep liberty and had sway with that.  I did not get much chance to play with the what options to try as my wife totaled that vehicle.  I replaced it with a Chevy Trail Blazer and the sway did go away.  I did have to drop the trailer lower on the ball so try that.
TerryM View Drop Down
Direct Link To This Post Posted: 21 Jan 2010 at 3:52pm
I have towed my 175 all over with my Liberty.  No problems at all.
Terry
Direct Link To This Post Posted: 21 Jan 2010 at 5:04pm
IMHO going with the class 3 was a good move.  Experience has taught me that there are two areas in life where one should refrain from practicing excessive "thriftyness":
1. Your spouse's birthday
2. Your towing equipment
To do so might result in, what I refer to as - "heap plenty problems".  I'll define "heap plenty problems" as: Your spouse and/or your trailer may want to separate from you in, what I'll refer to as - "an unpleasant manner".  I'll leave the words "an unpleasant manner" open to your interpritation.
The tongue down and sway bars are both good suggestions.
Hope to see you "out there"
Direct Link To This Post Posted: 21 Jan 2010 at 8:43pm
what i was meaning to say about the Liberty was that The hookup I had did sway but I'm thinking it was that the trailer was sitting higher.
Direct Link To This Post Posted: 22 Jan 2010 at 8:40am
    Thankyou for all your help, and we feel safe with our marriage no need for stronger wedding rings. Big smile   David and Danette
TrinityTurret View Drop Down
Direct Link To This Post Posted: 09 Oct 2013 at 10:28pm
Does the tongue weight of the 171 as listed on Forest River specs (225lbs) INCLUDE the battery and propane tank?
There's only one way...
Direct Link To This Post Posted: 10 Oct 2013 at 8:25am
My understanding from talking to them at the Indiana factory is it is with them.
retiredtraveler View Drop Down
Direct Link To This Post Posted: 10 Oct 2013 at 9:35am
Unless FR is different from other manufacturers, tongue weight is always given with nothing on it. That's due to a simple reason --- people load different size batteries (with different weights) on their trailer and ditto on propane --- one tank or two. A battery and propane will easily  add another 70+ pounds to the tongue weight.  A common mistake for newbies is that they don't realize how much weight is added to an RV once 'stuff' is packed into it, including the tongue.
   Now, because propane tank is standard on that unit, it's possible that is included. But battery is not a factory option. That comes from the dealer.
Looking hard at a pod
2006 Jayco 1206 (pup) with slideout, shower,solar
2005 Nissan Xterra (probably going to new Nissan Frontier)
Into hard-core hiking and biking
