List Your Mods:
 Post Reply Post Reply Page  <1 75767778>
pineview View Drop Down
Post Options Post Options   Quote pineview Quote  Post ReplyReply Direct Link To This Post Topic: List Your Mods:
    Posted: 13 Jun 2011 at 11:42am
I wanted to make a stove cover like other podders have done but I came upon an easier solution when walking through WalMart.  I purchased a wooden 16x20 galley tray with 2" sides, flipped it over to cover the stove and added a cutting board.   Works for me.
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 3:32pm
You can go into the "Post Options" to the upper-right of your post and edit it if you want.
Snowbound View Drop Down
Post Options Post Options   Quote Snowbound Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 1:04am
I don't know what happened. I was resizing the picture and suddenly it posted.
I made corrections as you suggested.  Thanks.
Tom
Tom and Bette
in our 177 "The Gastropod"
Post Options Post Options   Quote Snowbound Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 1:01am
Plastic back splash beside the stove
Clock mounted to be visible from the rDome.  Used velcro Command strips.
For privacy when travelling with friends, we used a spring-loaded bathroom cutain rod and a cut-down shower curtain.  Bette sewed a (loose) rod pocket to eliminate  the groumets.
Command hook next to door for the dog's leash and two Command hooks to hold a coat/hat rack on the wall above the switches for the slider, heater, etc. Since this picture we mounted a cut down over-the-door shoe organizer below the switches.
Picture shows when I paste it, but not after posting.
Mirror (48") on the outside of the bathroom door
A paper towel holder mounted with molly fasteners (a.k.a. hollow door anchors) and a Command hook to hang the sink cover which doubles as a splash guard.
3 compartment dispenser (soap, shampoo, conditioner) in corner of shower.
Tom and Bette
GrandPod View Drop Down
Post Options Post Options   Quote GrandPod Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 6:15am
 I have done the following Mods to our Model 177
1. Replace front jack with a folding one with that has a wheel
2. Added cabinet stay to the door of the cabinet which is over the stove and sink.
3. cut finger hole in lid of dinette seat storage compartment and added cabinet stay so that the  lid will stay open by itself.
4. Moved the legs of dinette table back 71/2 " so that it will fit closer to wall.
5. added hinge to lid of dinette seat where converter is located and added divider to seperate
    wiring from storage side also cut finger hole in lid.
6. Added 3" memory foam topper to bed.
7. Added stand alone 2 step enterance step.
8. Added 2 type 24 12Vdc batteries in parallel
Tom and Linda
R-Pod 177
Southwest Florida
VenturaDi View Drop Down
Post Options Post Options   Quote VenturaDi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2010 at 7:49pm
Among other things, installed a safety handle in the BR to make it easier to get up off the toi!
Diane
177 owner
rpodcamper.com View Drop Down
Post Options Post Options   Quote rpodcamper.com Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2009 at 10:35pm
Ok so It's not total a skylight but pretty close to one.  I pulled off the cover on our Fantastic Fan and replaced it with a clear unit.  Lets in so much more light now!  It is very easy to install as it took more time to get the ladder than it did to unscrew the 4 screws holding it on and replacing the cover.
Part number is - Dome Kit - Clear K1020-00
from the  catalog http://www.fantasticvent.com/faq/knowledge_base/manuals/manuals_assests/OEM%20cat.pdf
Just go to the website for the phone number www.fantasticvent.com/where_buy/where_to_buy.html
To talk about this mod or to ask questions please go to http://www.rpod-owners.com/forum_posts.asp?TID=969&PID=8623#8623
Before Install
Before
  Before
  Before
  After
  After
Post Options Post Options   Quote rpodcamper.com Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2009 at 3:25am
When we ordered our r-pod the first thing I had the dealer do was to remove the single tank holder and install the Dual Tank Holder.  We also changed over the gas regulator so both tanks are fastened at all times.  I went with a manual switch over regulator so I know when the one tank is empty and needs to be refilled.
To talk about this mod or to ask questions please go to http://www.rpod-owners.com/forum_posts.asp?TID=960&PID=8574#8574
Post Options Post Options   Quote rpodcamper.com Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2009 at 3:02am
The very first time I opened the door of my camper the shower access panel just jumped out at me.  I hated it!  The edges were unfinished wood and gave me splinters several times reaching in to turn on the light.  Managed to get another pocket like what is back in the bed and hung the pocket.  Looks way nicer now!
To talk about this mod or to ask questions please go to http://www.rpod-owners.com/forum_posts.asp?TID=959&PID=8572#8572
Post Options Post Options   Quote rpodcamper.com Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2009 at 2:43am
Pulled out the Blinds and installed Curtains
To talk about this mod or to ask questions please go to http://www.rpod-owners.com/forum_posts.asp?TID=958&PID=8570#8570
