Have You Done Any Mods?
 Post Reply Post Reply Page  <1234 52>
684 [81.43%]
10 [1.19%]
134 [15.95%]
10 [1.19%]
2 [0.24%]
You can not vote in this poll
yizit View Drop Down
Post Options Post Options   Quote yizit Quote  Post ReplyReply Direct Link To This Post Topic: Have You Done Any Mods?
    Posted: 09 Jan 2010 at 12:03am
Added risers.
Added front stabilizers.
Removed 2 burner stove and replaced with cutting board.
Added wire racks behind stove for additional shelves.
Added 6" in height to lower bunk for additional storage.
Removed upper bunk and added shelves in its place...this gave us a place to sit and a place to put our plastic containers for clothes, etc. towards the back of the lower bunk.
Added molding to top of refrigerator to keep items from sliding off during travel.
Added paper towel holder.
Added toilet paper holder.
Added mirror next to bath door.
Added tension rod in wet bath to hang wet towels.
Replaced cloth shower curtain with plastic and cut to fit.
Added numerous 3M hooks....love those things.
Added over the door hooks to bath door.
Replaced blinds with curtains.
Added memory foam to the queen bed.
Future plans/wish list:
Cut off switch for battery.
7' Sewer hose holder.
Trim dinette storage compartment lid so it can be opened without removing cushions
Move the switch for the water heater's electric element inside.
Replace fan cover with a clear cover.
Split lower bunk storage area into 2 separate compartments and separate plywood access covers for easy access to most used items in front.
Replace bunk mattress with something else...still working on that...maybe 2 separate foam cushions or padded lids.
Replace table legs with single post and tripod stand.
Former owner of 2009 172
Darlene & Jim, Ewok our Lhasa
Roada our 2004 Roadtrek C190Popular
GrandPod View Drop Down
Post Options Post Options   Quote GrandPod Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2010 at 1:22pm
 We have the R-Pod 177 model and have done the following mods.
 !. Moved the Dinette Table legs back 71/2 " so table will fit closer to the wall.
 2. Added hinge to the shelf over the sink and stove so that the cabinet door will stay open.
 3. Made a cover out of a Bamboo cutting board to place over the 2 burner stove.
 4. Added a 3" Memory Foam Mattress Topper on top of the mattress.
 5. Cut a finger hole in the lid for the storage compartment under the seat of the dinette.
 6. Added a portable 2 step enterance step for the trailer.
 7. Removed 1 light bulb out of each double light.
 8. Added battery cut-off switch.
 9. Am in the process of adding 3 12volt D.C. outlets for dc appliances such as tv/dvd player;
     coffee pot, 12v d.c fans and  outlet to be used for charging.
 10. Added 2 12v type 24 Batteries in Parallel.
 11. Added hinge to converter box lid where dinette seat is. also cut finger hole in lid and added
      stay so lid would stay open.
 12. added divider to converter box to make storage area and to keep storage area seperate from
      wiring.
          That it for now.
Tom and Linda
R-Pod 177
Southwest Florida
Tusten Traveler View Drop Down
Post Options Post Options   Quote Tusten Traveler Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2010 at 6:38am
Have done:
Mounted 19 inch TV/DVD to side of microwave cabinet on swivel mount
Replaced ironing board table legs with 2 pedestal (removable) legs mounted to carpeted board
Replaced bedroom miniblinds with curtains
Floor to ceiling shelf unit in bath behind toilet
Purchased small sofa table that stands flush against sofa
Purchased and placed Dometic cover made for stove which also acts as a backsplash
Cutting board for sink to create extra work space
Brought in on/off switch for electric water heater- mounted on dinette seat
Moved spare tire to tongue and mounted bike rack to back
3 inch memory foam mattress pad for bed. RV size queen sheets
Added front stabilizers and side levelers
Plan to do:
Cabinet stays or struts to overhead cabinets
Replace Fantastic fan cover with clear one
John and Linda
One 14 lb Cockapoo
2010 RPod 174
VenturaDi View Drop Down
Post Options Post Options   Quote VenturaDi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2010 at 2:16pm
Wow! Some of you folks have done SO many things!
We have:
-replaced the mattress with a 9" foam from Bed-In-A-Box  -  ahhhhh
-lots of throw pillows to make bed look more like day bed (not really a "mod", but changes the look)
-a bath safety bar on the wall of BR (to make it easier to get up off the toi toi!)
-an indoor/outdoor thermometer (so when it's COLD, we'll know just HOW cold!)
-mag-lite flashlight mounted just above the fire extinguisher just inside the door
-hinge thingy to the dinette seat lid to hold it open (will be doing the same for the over the sink cabinet)
-track installed on floor under dinette seat to keep storage bins from moving
-moved table legs so table fits against wall (seems to be the #1 mod!)
May be adding a Watts Premier RV water filtration unit under sink.  (Panel can be moved back after install, giving a bit more room under the sink)
Am going to try 3M picture hangers on the dinette back cushions to keep them against the wall.
Diane
177 owner
Podpatrol View Drop Down
Post Options Post Options   Quote Podpatrol Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2010 at 2:04pm
We haven't got real crazy yet, and our time is limited with other things in our life that we luv to do,
but since the purchase in October, we had done the following:
(177)
table mod
under bed support mod for access to WH and FURN
what we plan to do:
Dual battery mod
storage mods (cabinets and baskets)
TV mod (already have the Sat-Go)
removing cabinet above Bed
that's it for spring, and hopefully we're being realistic.
We Luv all the mods that everyone is doing and have posted.
Due to the fact that we are very busy people, I believe we'll
keep the mods down to a do-able pace.
barbanjoe View Drop Down
Post Options Post Options   Quote barbanjoe Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 9:48pm
Just finished today,
 converted to dual propane tanks and new vinyl cover from adco
 added second battery and quick disconnect when in storage
 had lift kit installed and purchased tire covers
 added cabinent door holders for the storage under seats to hold up when opened
 added spice rack with 6 hanging bottles from Ikea behind stove
 towel bar, basket and j hooks from Ikea behind sink
 Paper towel holder over sink
 microwave over tv/dvd/radio and 3m straps  to keep it from moving
 made wood stove cover for when more counter space is needed
 Hung small mirror by entrance door, added hooks to bath door and removeable bar on cabinent door below sink
 added memory foam pad to bed
 picked up a y connector and green hose to wash pots and clean outside without disconnecting white water hose.
 added heavy duty trans cooler to jeep and 4 inch riser for tow ball to level pod.
BarbanJoe
010 Rpod 171
02 Jeep 4x4
12 Ram 1500
pod-head View Drop Down
Post Options Post Options   Quote pod-head Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 9:13pm
Could you tell me which brand/color of stain you used on the untreated wood?
Post Options Post Options   Quote pod-head Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 9:21pm
Sorry, I should have been more specific-- Butterfly_Lee, you said you stained the untreated wood in your rpod. What brand/color did you use?
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 10:08pm
Welcome, pod-head.
Butterfly_Lee View Drop Down
Post Options Post Options   Quote Butterfly_Lee Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 12:38am
I use CABOT woodstain Pecan.  I took a draw in with me and use it to match color.
LeeClap
