  New Posts New Posts RSS Feed: tongue weight
Topic Closedtongue weight
 Post Reply Post Reply Page  123 5>
Direct Link To This Post Topic: tongue weight
    Posted: 25 Feb 2017 at 8:16am
I did find a 400 lb scale at Walmart for about $26. I checked yesterday with an assumed hitch height of 15", mine was 377 lbs. One 12 volt battery, electric jack, one full propane bottle, Stromberg Carlson A Frame Rack and my Generac IX 2000 gen set.
BTW - the picture addition was a great find.
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 25 Feb 2017 at 6:58am
Originally posted by osage
is the listed tongue weight on the pods dry or wet?
Get a cheap 350-400 pound bathroom scale (yes, they're out there). Block/chock those wheels!!
Connect to your tow vehicle, place the trailer coupler on the ball and lift the jack off the ground.
Put the scale under the jack, raise the tongue with the jack centered on the scale.
 You will know right away if you have exceeded 350 pounds. Or if you are under 350 pounds. No need to know EXACTLY in this case.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Direct Link To This Post Posted: 25 Feb 2017 at 6:51am
Thank you Grandpa Hiker.  Once all the snow melts and I can get to my 177 I will see what the tongue weight is.  Great pictures! Indeed, worth a thousand words.
Grandpa Hiker View Drop Down
Direct Link To This Post Posted: 25 Feb 2017 at 3:54am
Here is a link to a site with photos on how to make the tongue weight scale. I drilled holes through the pipes & screwed them into the beam so I do not have to be concerned about  the pipes rolling out of place.
Rob & Becky
2015 R-179 Pod aka Piddle Pod
CharlieM View Drop Down
Direct Link To This Post Posted: 24 Feb 2017 at 8:15pm
Originally posted by mcarter
Charlie,
Correct me if I am wrong, when you do tongue weight you want to be as close to possible to your tow height.
Correct.
Direct Link To This Post Posted: 24 Feb 2017 at 7:55pm
Unfortunately, I will be unable to get a good reading until after our 'Pod is repaired. The heaviest item, our dual-6V batteries, has been removed in preparation for it to go to the factory. A number of other mods have also been removed, and it is emptied out of almost everything movable. The last time I tried was when I had everything, including the Stromberg-Carlson Trailer Tray and generator in addition to a full tank of water. The tongue weight was around 450 lbs.
Now that we have the truck, there will be no need to carry the generator on the trailer tongue so I will likely consider not reinstalling the rack. I might find it useful for other things though.
Direct Link To This Post Posted: 24 Feb 2017 at 3:18pm
Charlie,
Correct me if I am wrong, when you do tongue weight you want to be as close to possible to your tow height. All a teeter/totter theory. BTW - Enjoyed the engineer dialogue, haven't done that since I retired, except with myself. Maybe we should start a little engineering group, only kidding. Still would be interested in what you all are getting for a tongue weight.
mjlrpod View Drop Down
Direct Link To This Post Posted: 24 Feb 2017 at 3:05pm
Originally posted by StephenH
Okay, I'm a bit confused. In your example above, the weight at the jack (P) was 300 lbs. The result of your formula (W) was 285 lbs. Did you mean the weight at the ball will be slightly less than at the jack?
That was my thought exactly. your first statement, the weight is slightly less at the ball, than at the jack i believe is accurate. As you get further away from the fulcrum (the axle) the tongue would get lighter and lighter.  Its the " give me a lever long enough and i'll move the world" scenario.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
TheBum View Drop Down
Direct Link To This Post Posted: 24 Feb 2017 at 2:30pm
Correct. Further from the axle. The pivot point (fulcrum) is the axle to which everything is referenced.
It goes back to the torque argument. To rephrase what Charlie said, the further the distance from the pivot point, the lower the force needed to maintain equilibrium.
And, yes, I do have an engineering degree, but electrical and not mechanical/civil. I learned most of my mechanical physics from building and flying RC helicopters. Torque is a very big deal in that application.
Direct Link To This Post Posted: 24 Feb 2017 at 11:53am
I would very interested in knowing what some of you are getting for tongue weight, I plan on checking mine later today. Right now I have a single propane tank, single battery and my gen set mounted on an a-frame rack. I have NOT checked it with the gen set mounted. I have a 400 lb scale I bought at WalMart.
