Page <1 2345> |
Author | ||
![]() Posted: 24 Feb 2017 at 11:43am |
Correct. Further from the axle. The pivot point (fulcrum) is the axle to which everything is referenced. |
I would very interested in knowing what some of you are getting for tongue weight, I plan on checking mine later today. Right now I have a single propane tank, single battery and my gen set mounted on an a-frame rack. I have NOT checked it with the gen set mounted. I have a 400 lb scale I bought at WalMart.
It goes back to the torque argument. To rephrase what Charlie said, the further the distance from the pivot point, the lower the force needed to maintain equilibrium. And, yes, I do have an engineering degree, but electrical and not mechanical/civil. I learned most of my mechanical physics from building and flying RC helicopters. Torque is a very big deal in that application. |
That was my thought exactly. your first statement, the weight is slightly less at the ball, than at the jack i believe is accurate. As you get further away from the fulcrum (the axle) the tongue would get lighter and lighter. Its the " give me a lever long enough and i'll move the world" scenario.
Charlie,
Correct me if I am wrong, when you do tongue weight you want to be as close to possible to your tow height. All a teeter/totter theory. BTW - Enjoyed the engineer dialogue, haven't done that since I retired, except with myself. Maybe we should start a little engineering group, only kidding. Still would be interested in what you all are getting for a tongue weight. |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Online Posts: 6437 |
Unfortunately, I will be unable to get a good reading until after our 'Pod is repaired. The heaviest item, our dual-6V batteries, has been removed in preparation for it to go to the factory. A number of other mods have also been removed, and it is emptied out of almost everything movable. The last time I tried was when I had everything, including the Stromberg-Carlson Trailer Tray and generator in addition to a full tank of water. The tongue weight was around 450 lbs.
Now that we have the truck, there will be no need to carry the generator on the trailer tongue so I will likely consider not reinstalling the rack. I might find it useful for other things though. |
Correct. |
Grandpa Hiker ![]() Senior Member ![]() ![]() Joined: 04 Jan 2015 Location: Martinsville, V Online Status: Offline Posts: 143 |
Here is a link to a site with photos on how to make the tongue weight scale. I drilled holes through the pipes & screwed them into the beam so I do not have to be concerned about the pipes rolling out of place.
Rob & Becky
2014 Ford Explorer 3.5 SOHC V6 2015 R-179 Pod aka Piddle Pod "Life is not about waiting for the storms to pass, it is about learning to dance in the rain!!" |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3350 |
Thank you Grandpa Hiker. Once all the snow melts and I can get to my 177 I will see what the tongue weight is. Great pictures! Indeed, worth a thousand words.
ToolmanJohn ![]() Senior Member ![]() Joined: 23 Apr 2014 Location: Connecticut Online Status: Offline Posts: 451 |
Get a cheap 350-400 pound bathroom scale (yes, they're out there). Block/chock those wheels!! Connect to your tow vehicle, place the trailer coupler on the ball and lift the jack off the ground. Put the scale under the jack, raise the tongue with the jack centered on the scale. You will know right away if you have exceeded 350 pounds. Or if you are under 350 pounds. No need to know EXACTLY in this case. |
Page <1 2345> |
