  New Posts New Posts RSS Feed: tongue weight
Topic Closedtongue weight
 Post Reply Post Reply Page  <12345>
CharlieM View Drop Down
Direct Link To This Post Topic: tongue weight
    Posted: 23 Feb 2017 at 6:37pm
Yes angle iron will work. Even aluminum (aluminium? Wink) will work if stout enough. The important part is only a thin knife edge contact perpendicular to the 2x4. BTW, there are lots of us engineer types hangin' around.
Direct Link To This Post Posted: 23 Feb 2017 at 6:33pm
I agree Bum, doesn't appear I am the only engineer on this forum:)
TheBum View Drop Down
Direct Link To This Post Posted: 23 Feb 2017 at 5:56pm
I think the theory is based on torque. With the brick defined as the pivot point, the torque of the system would be the weight of the tongue (W lbs) times the distance from the tongue weight to the brick, or W ft-lbs. The torque along all points of the 2x4 must be the same, so at triple the distance, the weight to get the same torque would be 1/3 W.
Direct Link To This Post Posted: 23 Feb 2017 at 4:50pm
Bum,
I think yes, I used pipe because I had pipe, I think Charlie has a good point but I didn't want to "cut wood". I used what I had. The process is the same and allows you to use a bathroom scale. You can't put some wimpy angle iron under it, but that's common sense and we have that. I like pipe because it has many uses, wood seems to have one purpose once it's cut. To me.
Direct Link To This Post Posted: 23 Feb 2017 at 4:22pm
Would steel angle iron work as well, or is the Pod too heavy?
Direct Link To This Post Posted: 23 Feb 2017 at 2:11pm
Thanks Charlie, makes sense.
Direct Link To This Post Posted: 23 Feb 2017 at 12:11pm
The idea of the pipe is to provide a sharp edge  so you know exactly where contact is made. You can get the same effect by slicing a 6" length of 2x2 lengthwise at a 45 degree angle yielding two 6" lengths with triangular cross sections. Place one each on the scale and brick with the wide sides down so you have two edges pointing up. That provides very accurate points to measure your 1 and 2 feet. A bit more trouble but it eliminates the rolling pipe problem.
Direct Link To This Post Posted: 23 Feb 2017 at 10:19am
Good question, my only guess is the pipe distributes weight more exactly that the wider 2X4 would and has more strength than a 2X2.
Happy Tripping View Drop Down
Direct Link To This Post Posted: 23 Feb 2017 at 7:35am
This is very nice.
I assume the brick is so that it's reasonably level with the bathroom scale, but why not use a foot-long 2X2 or 2X4  rather than a pipe?
Direct Link To This Post Posted: 22 Feb 2017 at 8:58pm
mcarter, you must be an engineer!
