Page <12 |
![]() Posted: 01 Feb 2017 at 9:21pm |
I had that Yamaha and it didn't have a problem. However you lose power the higher you go and the hotter it is, so you can lose up to 1/3 of your power at altitude on a hot day. Plus the A/C is harder to start the hotter it is. So it might work fine in your driveway but not work right when you need it the most. Use synthetic oil and test it on the hottest day of the year.
Farrier2112 ![]() Newbie ![]() Joined: 26 Nov 2016 Online Status: Offline Posts: 7 |
Thanks for the info. Why Synthetic oil? What weight and brand should I buy? I've been using ethanol free gas in all my small engines. I foresee a problem if I need to buy more gas in different states. Thanks again for your help,
Blue Highways ![]() podders Helping podders - pHp ![]() ![]() Joined: 20 Sep 2016 Location: NC mountains Online Status: Offline Posts: 86 |
Wow, GREAT intelligent discussions. I would say R-Pod owners here are 'smarter than the average bear'.
Stephen, I could have appreciated you as a valued math & physics tutor back in school for sure.... Sometimes, I will rack up a little extra momentum on a highway that's dipping across a valley, in order to get past a cluster of Semi trucks that are really going to bog down on the next incline. I really got Our Pod's message about the increased energy (21%) in a crash based on the factor of elevated speed. Maybe I will reconsider, and "tow slow, amigo" ( I mean, what's the hurry, the campsite's reserved. ) Thanks all, --B
I think you mean Our Pod for the physics tutor. He is the one that gave the formula. I was just using it to generate some examples. I also got the message. |
voisj ![]() Senior Member ![]() Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
This thing I learned today. After 65MPH my mileage plummets, now I understand why. Thanks! John
malkbean2 ![]() Groupie ![]() Joined: 31 Jan 2017 Online Status: Offline Posts: 80 |
i drove from chicago to key west and back on mostly interstates at 60 mph with 178 rpod and passed only 2 vehicles (not counting mountain areas). Every single semi passed me and there was a lot of them. By the way I experienced sway (with a sway bar) from some semis after they passed not during or before they passed. and only some semis not most of them. Weird huh?
2016 Grand Caravan was TV |
Not all semis are set up he same. Some have the panels for directing airflow at the bottom. It may be those that send more of a surge of air your way and cause more sway. I noticed it as well, but I did not note which ones were the ones which caused more sway. I'll have to try to figure that out next time we are out. Also the speed at which the semis are traveling relative to you probably play a factor in it as well.
Of course, if one is in front of you and traveling at the same relative speed, it is nice to drop in behind and take advantage of some drafting help. I don't like to follow close enough to take full advantage though. |
Page <12 |
