jimcarpin
Topic: 2015 RP-178 Shelf Over Bed w/ Baskets Mod Posted: 18 Aug 2016 at 2:45pm |
Very nice shelf. What brand and color stain did you use?
JAC
Podster
Posted: 18 Aug 2016 at 8:07pm |
Purchases as is without alterations at Lowes in the closet/shelf organizer section. I'm told these babies are getting hard to find. Good luck!
Cliff & Raelynn
Ranger 4.0/178
bigcat
Posted: 12 Dec 2016 at 1:16pm |
Jackwho, I love this! How do you extend the pads to create a enough tension? Or is the valance bearing the weight?
Big Cat
2017 179
Dragon Pilot
Posted: 18 Dec 2016 at 11:53am |
So... you drilled a 1/4" hole into the shelf end and then inserted the bolt head into the hole... have I got that right? How deep did you drill?
RP-178, 1997 Explorer 5.0 V8 AWD
Bboudens
Posted: 20 Dec 2016 at 9:22am |
Excellent Idea! How much head room do you have between the shelve and the mattress? I have the pod in storage for the winter other wise I'd be able to find out for myself.
Keep your stick on the ice
2016 178HRE
2011 Silverado 1500
twodues
Posted: 01 Mar 2017 at 9:28am |
jackwho This method worked great! Movable/removable and no drilling into the pod.
bigcat
Posted: 01 Mar 2017 at 10:22am |
Originally posted by twodues
jackwho This method worked great! Movable/removable and no drilling into the pod. |
twodues, How do you extend the pads to create a enough tension? Or is the valance bearing the weight?
Big Cat
2017 179
twodues
Posted: 01 Mar 2017 at 11:45am |
The valance bears some weight. The set up for the tensioners is like this: 10-32 bolt thru non-skid pad, 10-32 nut tightened down to hold pad at the end of the bolt. End of shelf rails drilled 1/8 pilot 2 1/2" deep, then larger hole to accommodate the bolt diameter. One last drill out to 5/8" depth to set the 10-32 tee nut in the end of the shelf rail. I also put a second nut on each bolt tightened against the tee nut to prevent the tensioners from turning further into the tee nut.
bigcat
Posted: 20 Mar 2017 at 2:52pm |
I just had a crazy thought... Please let me know if I am indeed crazy.
I need a new shower curtain rod for my home and I had the thought to use two curtain rods to span the width over the bed, then rest the shelf on the curtain rods. Any thoughts on a good, or bad idea? I found curtain rods on Amazon that will extend long enough and can support 30 lbs each.
https://www.amazon.com/gp/product/B00KA3DS1U/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Big Cat
2017 179
Podster
Posted: 20 Mar 2017 at 10:05pm |
I'm not a fan of any solution that results in putting any force, at all, against the sidewalls. I mean like zero. ![Smile Smile](smileys/smiley1.gif)
Cliff & Raelynn
Ranger 4.0/178
