Page 12> |
RickyTerzis ![]() Newbie ![]() Joined: 18 Jul 2017 Location: Miami,USA Online Status: Offline Posts: 1 |
![]() Posted: 19 Jul 2017 at 11:56am |
Hi...i am a new user here. As per my knowledge there is no practical way to run the air con using battery power.
Maybe with the back of a pickup truck full of batteries, but that would
weigh at least half ton and I don't know how long that might work or
what it would take to recharge the batteries.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3331 |
Good to know, thanks for the update Russ.
Rustler ![]() Senior Member ![]() ![]() Joined: 07 May 2016 Location: S. Oregon Coast Online Status: Offline Posts: 100 |
Thanks for your kind comment. Best abandon any use of air conditioner except on shore power or mobile generator. It is just way too big of a power draw to run off solar/battery power. You would need a huge battery and inverter to supply the necessary AC power for the air conditioner. With boon docking one must of necessity do without some of the amenities available with commercial electric power. But I have camped out 4 nights (at the Golden StateStar Party) using just solar power and propane. It did allow using lights, and an Endless Breeze fan to move some air for personal comfort. The temperatures reached the mid-nineties each day. But that 185-watt panel had way more capacity than was needed. Even after my telescope running off battery power all night, the solar panel recharged the battery quickly each morning and kept up with daytime loads.
Russ
2009 Toyota RAV4 V6 w/ tow package 2016 Rpod 171 HRE |
mrharrybay ![]() Newbie ![]() Joined: 25 May 2015 Location: Northern Connecticut Online Status: Offline Posts: 13 |
No, not thinking that at all, dual batteries just seems like a good overall rPod practice which I should adopt. It's clear to me that a/c off the grid is only going to come from a generator. Thanks.
2015 RPOD 178, 2015 Chevy Colorado Z71 CC SB, Tekonsha Primus IQ, Lippert hitch, Cequent sway bar, countless nameless hitch pins who will give their lives while I learn how to back this thing up
Just to be clear, two batteries won't come close to running the air conditioning either. Not sure that's what you're thinking, but as Furpod said, there is no practical way to run the air con using battery power. Maybe with the back of a pickup truck full of batteries, but that would weigh at least half ton and I don't know how long that might work or what it would take to recharge the batteries. That would be quieter, but way more expensive than a good 2400+ watt generator. TT |
FJ Cruiser |
Thanks, the dual battery set-up is also something that looks worth adopting for general efficiency, too.
Boondocking and a/c are incompatible. The only way to run the a/c (reasonably) off grid is with a generator. Producing mains power from a battery bank for a sustained load isn't something easily, compactly, or cheaply done. Solar is used to recharge the batteries, nothing else. You don't "run" anything on solar. |
Impressive!
Well done! I've been thinking about adding solar for 2017 boondocking, do you feel the solar (any solar) will not run the air conditioning? That will be a deal-breaker for the Frau.
I hadn't really totaled it up before. But here's an estimate:
For comparison a 120-watt, 12-volt Zamp solar panel with Pulse Width Modulation (PWM) controller goes for around $641. While it is a more polished and easier to use setup, it comes with the less expensive & inferior PWM controller. But the Zamp outfit is folding which makes for easier storage. Ecoworthy and Renogy also make folding solar panels. The Solarland 24-volt solar panel is quite a bit more expensive than a similar 12-volt panel. The maximum power point tracking charge controller is more expensive than a similar pulse width modulating charge controller. But it will harvest a lot more energy from an expensive solar panel. And it allows using high voltage panels which will operate with less power and voltage loss. I can also use my 185 watt, 24 volt panel with the same controller. I will be using this solar charger at campgrounds without electric hookup and at each summer's Golden State Star Party. I might also make it to next year's Oregon Star Party. Both outings will be boondocking.
Russ
Page 12> |
