List Your Mods:
 Post Reply Post Reply Page  <1 1819202122 78>
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Topic: List Your Mods:
    Posted: 15 Nov 2016 at 9:46pm
Post what you are having a problem with so we can help.
rGod2013 View Drop Down
Post Options Post Options   Quote rGod2013 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 11:41pm
I give up. Can't figure how to use this site right. I'm sorry but this site is not user friendly, at least not for me. Too much back and forth. Can't figure out how to post things right, even with site help. Things disappear. I started using cut and paste cause I cannot figure out how to pick up my file and place it, (or is it post it?) in a topic? OR am I always making a new topic, or is it a post? I do a search and using the simplest words cannot find a topic I know I've read before. Lots of good info here. I am just having a hard time learning the ropes.
thanks for the help
voisj View Drop Down
Post Options Post Options   Quote voisj Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 1:22pm
The front led lights must pass by the slide motor under the slide out and they used it to power the slide motor.if you take the cover off your elec panel and just remove fuses you can find which wire and fuse does which lights and which one does the slide. You can also unscrew the main panel and slide it out and see the rats nest they call wiring and tap into any wire you want to switch
SLOPODMODS
John&Sue,SLO,CA
Alaskaflyer View Drop Down
Post Options Post Options   Quote Alaskaflyer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 11:16am
Originally posted by Grandpa Hiker
Installed 6 ft. tool box from Northern Tools. Had to move propane tank 3 1/2" forward.
Very nice.
2016 RP-176
Grandpa Hiker View Drop Down
Post Options Post Options   Quote Grandpa Hiker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 3:44am
Rob & Becky
2015 R-179 Pod aka Piddle Pod
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 5:23pm
The light switch mod is nice. However, it will not work for our 179 as the switch for the porch light is not near the door, but is around the corner on the wall of the pantry near the bathroom door. I may be able to figure out how to put switches for the porch light and at least one interior light near the door, but it is one of those "when I get a round tuit" projects.
Post Options Post Options   Quote Alaskaflyer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 5:02pm
I finished the project to install a wall switch for the overhead light nearest the door. By design or coincidence that light was on its own circuit and the wire ran from the panel to the ceiling right behind the existing switches just inside the door. I removed the old single switch controlling the porch light, pulled the wire matching the color I observed on the  circuit through the existing hole, clipped the hot wire and installed those ends and the porch light on a new double switch that I found on Amazon that nearly matched the style of the existing white slide out switch.
I wonder if Forest River originally intended to install a wall switch for that one light on some models then chose not to for whatever reason. Now my boys can reach the light switch and any of us can step inside the door at night without needing a flashlight for the first couple steps.
birderdiane526 View Drop Down
Post Options Post Options   Quote birderdiane526 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 11:41am
Hi! We are in a 179 and see you tapped into the power feed from the slide. Would you tell us where/how you did this? Thanks.
Diane and Michael
2007 Toyota Tundra
BLOG:Podding in Paradise,
birderdiane526.blogspot.com
Jonknite View Drop Down
Post Options Post Options   Quote Jonknite Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 8:46am
RGod2013,
You may want to try this group. Posting is easy on Facebook and you'll get a LOT of responses.
https://www.facebook.com/groups/RPodOwners/
Post Options Post Options   Quote voisj Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 1:18pm
In the  introduce yourself window New Topic is for you to introduce yourself, a new post is a new topic.
Before you click Introduce yourself go down 3 lines to Podmods, maintenance, tips and tricks. This is where you will find questions people have posted about specific items. Scroll down and click whatever interests you, there are 58 pages.  Use the search button up at the top the to search for keywords like "cabinets" or A/C.  A straight Category breakdown would be nice but the conversations wander and things would end up out of place ( in my opinion) and the search works well for specific topics. Maybe start a topic " All thing plumbing"?
Good Luck!
Rgds John
SLOPODMODS
John&Sue,SLO,CA
