  New Posts New Posts RSS Feed: Tip for the Fridge
Topic ClosedTip for the Fridge
TerryM View Drop Down
Direct Link To This Post Topic: Tip for the Fridge
    Posted: 08 Dec 2009 at 5:11am
When the camper is not being used the door should be left open.  I think we all know this.
The tip is this.  Use that tiny ice try to block open the freezer compartment.  That will also keep the fridge door open.  So if your parked at an angle the door will not close by itself.
Terry
cane2 View Drop Down
Direct Link To This Post Posted: 08 Dec 2009 at 7:14am
The fridge in my fiver had a latch that would stop at about half  inch before it closed all the way it worked great to hold it open and would not swing all over the place. I have not checked out my pod to see if it does the same thing, they are both dometic. Today is not the day for me to go out and look as we are getting 1 -6 inches of cold blowing snow.
Pie_Pod View Drop Down
Direct Link To This Post Posted: 08 Dec 2009 at 7:55am
That's a handy tip!
We stored our Pod for the winter and we did leave our fridge open...but I was worried the door would close.  Ted said it was fine and not to worry.   Next time I will use the little ice cube tray!
(cindy files this tip away for future use)
~Cindy_CP
(Pod_Patrol's girl)
177
Tusten Traveler View Drop Down
Direct Link To This Post Posted: 08 Dec 2009 at 11:06am
<<Walking out to the pod with a small ice tray in my hand and my head down>>  Actually, I didn't know that....thanks. Embarrassed
John and Linda
One 14 lb Cockapoo
2010 RPod 174
Direct Link To This Post Posted: 08 Dec 2009 at 12:29pm
Yup, it'll be musty city by spring.  Worse still if you leave it closed for a month between trips while it bakes in the humid summer sun.  Dead
In my popup we kept a sponge between the seal and the door frame - but the flip-down kitchen kept the door "closed".  Not really an option here.
Direct Link To This Post Posted: 08 Dec 2009 at 12:47pm
It works great.  Put that little ice tray where the freezer door hinges and NOTHING closes.  Just don't forget to remove it and close the door when moving.
Terry
GATOR View Drop Down
Direct Link To This Post Posted: 08 Dec 2009 at 2:15pm
My 177 has a pull out latch that locks the door open. It stays open about 3/4 of an inch.
Gator & Tammy
2010 RPod 177
2006 Toyota Tacoma 4x4
Mary and Don View Drop Down
Direct Link To This Post Posted: 08 Dec 2009 at 2:40pm
Another tip for that ice tray is to use it under the wire rack.  It fits.  I also purchased some small trays from Campers World that fit underneath the rack.  If we're on a long trip, I totally fill up the freezer with meat, so it's nice to use the space under the rack for ice cubes - even if they are small.
Mary
Direct Link To This Post Posted: 08 Dec 2009 at 2:54pm
What about your freezer?
Terry
Direct Link To This Post Posted: 08 Dec 2009 at 3:06pm
Welcome Gator, I'll have to look for that latch, I don't remember seeing it.
The freezer compartment isn't really sealed well, I wouldn't worry about it.  You could just pull it out.
