  New Posts New Posts RSS Feed: Winter covers
Topic ClosedWinter covers - Event Date: 15 Oct 2016
mlusa View Drop Down
Direct Link To This Post Calendar Event: Winter covers
    Posted: 15 Oct 2016 at 10:27am
Good morning, We purchased a new 180 this year as r and love it. We camped in New York since May and now are going to winterize the camper. Any suggestions on which cover to use?
Direct Link To This Post Posted: 15 Oct 2016 at 11:14am
I believe the 180 is essentially the same as the 179 in door placement and length. If so, the cover for the 179 should fit the 180 as well. We got the Classic Accessories cover. It works well.
Direct Link To This Post Posted: 15 Oct 2016 at 11:18am
Thank you, that is one of the brands that we where looking at, but I do have to check the location of the door to confirm it would match!
Direct Link To This Post Posted: 15 Oct 2016 at 1:06pm
The door on a 180 is in the same place as a 179.
Direct Link To This Post Posted: 15 Oct 2016 at 2:03pm
I also saw one site where the cover was listed as "179/180." Even though Amazon does not specify 180, it will fit.
this_is_nascar View Drop Down
Direct Link To This Post Posted: 16 Oct 2016 at 7:18am
From what I understand, the 179 and 180 share the same shell, with different placement if the windows.
"Ray & Connie"
- 2017 R-Pod RP-180
ParPod View Drop Down
Direct Link To This Post Posted: 29 Oct 2016 at 10:26am
We used the Classic cover on our 179 and it works well.  Check closely through because the first one we got said it could be used for a 179 but nothing doing.  Door was in the wrong spot and it was too small.  The replacement went on without any problems - turn it inside out and start at the front.  Took two of us a couple of minutes and the cover was on.
Bob&Margaret
2017 179
2016 Toyota 4Runner
2 sets of Golf Clubs
NickLPod View Drop Down
Direct Link To This Post Posted: 29 Oct 2016 at 10:57am
We just tested the Classic Accessories PolyPRO 3 R-Pod Travel Trailer cover Model 4 (part # 80-197-171001-00) on our 2016.5 (green) 180 (inc. AirCo & TV antenna on roof) which fit fine.
I bought a length of foam pipe insulation 1/2 inch internal diameter to cover any sharp objects (gutters, Dome awning channels) to prevent snagging / tearing.
The zipper door opening is in the correct location.
2016 R-Pod 180
2011 Audi Q5 3.2 V6
Wife Carole
Dog Corra
Direct Link To This Post Posted: 29 Oct 2016 at 3:23pm
I have a Classic Accesories cover, when removing it today it tore at points that don't have any stress on them.  I have owned the cover less than a year, granted the TV is stored outside in TN, but I really expected better quality.  Not happy with buying a new cover every year.
IL-Podders View Drop Down
Direct Link To This Post Posted: 29 Oct 2016 at 6:06pm
mcarter, your cover should be covered under warranty, mine was.  All you need is your invoice and a picture or two of the damage.  They sent me a new one right away.  I used gorilla tape in the areas where ripples occurred in the old one and have not had any issue with the new cover.  Contact Classic Accessories. I found the very accommodating.
Marv-N-Kathy
2015 179 RPod
2016 Chevy Tahoe
