Originally posted by Mafghine
Hello, does the a/c unit only run on 30 amp?The smell from new fridge startup, does it go away? Safe to use the m/w on a 15/amp to a 30/amp plugin adapter? The clock is on m/w when plugged into 15 amp. Thank you for any help. Just got my rpod 2017 179 yesterday. |
To be safe run the AC from a 30 amp circuit. A good 20 amp circuit will work but, don't run anything but the AC. To run anything less than 30 amps, you will need an adapter for your power cord...see next comment.
The microwave, yes you can do this. However, spend a few dollars more and get the "dog bone" type adapter. The black "pucks" have been questionable. As with the AC, when using the microwave, turn off everything else.
