List Your Mods: |
Page <1 5051525354 78> |
NutPod ![]() Newbie ![]() ![]() Joined: 29 Jul 2016 Location: Canada Online Status: Offline Posts: 25 |
![]() ![]() ![]() ![]() Posted: 09 Sep 2016 at 10:37pm |
Yes they are external speakers that came with the trailer but in that picture I added the two roof vent covers.
Bcmckean ![]() Newbie ![]() Joined: 16 May 2016 Online Status: Offline Posts: 13 |
Ok thanks! I may have to get in contact with Forest River to see about purchasing a couple to add to mine since I don't have any.
CLT-NC R-Podder ![]() Newbie ![]() Joined: 18 Mar 2016 Online Status: Offline Posts: 8 |
This is our newest "mod" to create additional storage space while we are camping. We removed the factory galley rail above the microwave and added an 8" wide shelf across the entire slide-out.
Joe & Erin
2016 178 towed by 2016 Toyota Tacoma double cab 4x4 |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6456 |
Nice work!
Jonknite ![]() Newbie ![]() ![]() Joined: 25 May 2015 Location: Placitas, NM Online Status: Offline Posts: 19 |
Third window over the dinette of an R-178
One thing I missed when I upgraded from a pop-up to the R-Pod was the amount of light inside. I added the porthole in the door as many have done, but I wanted more light in the dinette area. I ordered a 12" X 30" RV window and here is the result: ![]() I built a frame out of 1X3's. The rounded corners were cut from 2 X 4's using a bandsaw. ![]() Cut out a hole in Pod the same size as the frame. The bottom of the hole is even with the top of one of the framework members for solid attachment of the frame. The sides were screwed into the next frame member up which was cut after the hole. ![]() Then I used high strength adhesive to add another frame member for screwing in the top of the frame and to give the inner and outer skin some strength. ![]() Screw in the frame and then install the window as per the manufacturers directions. Done! |
kkomorn ![]() Newbie ![]() Joined: 17 Oct 2015 Online Status: Offline Posts: 7 |
That is just awesome. Seriously.
And FR said it couldn't be done. I would have loved a window in the front wall in our 171. Make sure you add a cover on the outside when you tow to protect against road debris.
CLT-NC R-Podder Looks great, what color stain did you use to match the rest of the wood?
We took a drawer from the kitchen cabinet, as well as a piece of the wood we were staining, to Sherwin Williams and they matched it. They did a great job!!
Joe & Erin
Great, thanks! Looks like they did a good job... and your handy work looks good as well!
