cdsmith
Topic: Fridge on propane question Posted: 03 Sep 2016 at 6:04pm |
So.. I'm at a campsite and I have the fridge on propane. The question is should the fridge be cycling (re-igniting the burner - it is doing this) or should burner stay on constantly? This is only the second time to dry camp and I didn't notice this happening the last time (not that it didn't - just didn't notice)
cd
CharlieM
Posted: 03 Sep 2016 at 6:20pm |
The burner will ignite whenever the thermostat requires cooling. In cool weather it will cycle on and off. In hot weather it may run continuously.
cdsmith
Posted: 03 Sep 2016 at 6:37pm |
Good to know... I thought that might be the case, but needed confirmation from someone in the know.
Thanks... I can relax now.
Have a good weekend.
cd
mtbmitch
Posted: 04 Sep 2016 at 11:18pm |
Also important to pull exterior fridge access panels off and blow the dust out of everywhere a few times a year. On a separate note, our pod had some major air passage ways into trailer that were not properly sealed off above and below the fridge.
enjoy the fresh air
cdsmith
Posted: 05 Sep 2016 at 8:31pm |
I did blow the dust out a few months ago - I will do it again before I use the fridge again... I did discover that the power going to the fans (mounted in the back) was disconnected - don't know why. Maybe the thermostat that controls them is not working and the previous owner just disconnected them. The fans work and I have power, so just don't know if the there is a problem with the thermostat - I'm thinking that if I take a hair dryer to the thermostat it should tell me if it is working... cd
WillThrill
Posted: 05 Sep 2016 at 11:29pm |
cd |
If the burner is on, you will be able to feel some warm exhaust coming from the vent behind your refrigerator outside.
2014 Hood River 177
2005 GMC Envoy XL
M&M
Posted: 06 Sep 2016 at 3:52pm |
Good Afternoon All, We're new owners and I have a simple, related question. To run the fridge on propane I just need to have the propane tank open and select the gas button on the front of the fridge, correct? Thanks, Marty
2017 179 "Big Sexy"
2012 Honda Pilot
Posted: 06 Sep 2016 at 5:21pm |
The brain of the fridge needs 12v also, but yes.
Posted: 07 Sep 2016 at 6:59pm |
Also be sure to purge the gas lines by lighting a burner on the stove. If there is too much air the fridge will "time out" after several cycles. Purging also helps the WH and furnace to light.
Old Surfer
Posted: 10 Sep 2016 at 1:44pm |
My ref. won't light up too. So I'll have to clean it. Witch panel do take off and with what?
I have never ran my R-Pod 179 on propane. I've had it for 1 1/2 years.
Thanks for the help.
