  New Posts New Posts RSS Feed: Refrigerator resetting in driveway
Topic ClosedRefrigerator resetting in driveway
ribet View Drop Down
Direct Link To This Post Topic: Refrigerator resetting in driveway
    Posted: 09 Sep 2016 at 8:17pm
I tested the Amp draw yesterday of RP171.  Charger converter draws 3.04 amps on a 3/4 charge level battery and when the electric refer is turned on to ac it adds a extra amp. total 4,04 amps.
Direct Link To This Post Posted: 08 Sep 2016 at 9:57pm
That will keep it from cooling!
bigcat View Drop Down
Direct Link To This Post Posted: 08 Sep 2016 at 5:35pm
just heard from the service department... it's now leaking ammonia so a new fridge is on the way.
Big Cat
2017 179
Direct Link To This Post Posted: 08 Sep 2016 at 5:34pm
Just heard from the service department... the fridge is also now leaking ammonia so a new fridge is on the way.
Big Cat
2017 179
Direct Link To This Post Posted: 07 Sep 2016 at 12:05am
Flat6s, same issue with the eyebrow panel. Looks like I need a new one.
Big Cat
2017 179
Direct Link To This Post Posted: 02 Sep 2016 at 8:57am
I dropped it off for service yesterday, and will update this when I get more info.
Big Cat
2017 179
flat6s View Drop Down
Direct Link To This Post Posted: 01 Sep 2016 at 9:59pm
Just got my new 180 back for repair of defective refrigerator eyebrow circuit board.  This board runs the buttons on front of fridge. There is also another board on back of fridge. Because your fridge won't run on any power source, kinda points to one of those circuit boards being defective.
densmorema View Drop Down
Direct Link To This Post Posted: 01 Sep 2016 at 5:47pm
Fur pods right about the fridge needing 12v to run just like your lights,you might want to check your converter fuses which are the 40a fuses,also the converter breaker.
Mike and Cherie
Michigan
2015 R179 2016 silverado
Direct Link To This Post Posted: 01 Sep 2016 at 12:06pm
You guys! I found the GFCI outlet. It's by the furnace and the only place I didn't check for an outlet. Go figure.
Big Cat
2017 179
Direct Link To This Post Posted: 01 Sep 2016 at 10:29am
Charlie,
Thanks. I'll check.
