  New Posts New Posts RSS Feed: Axle brand
Topic ClosedAxle brand
JHoffman View Drop Down
Direct Link To This Post Topic: Axle brand
    Posted: 12 Aug 2016 at 10:47pm
Does anyone know what brand axle is installed on the 2016 RPods and what is the weight rating for them? We have a 2016 176T if that makes a difference.
2016 176t Rpod the "Hoffpod"
2010 Toyota Tundra 5.7L
Direct Link To This Post Posted: 12 Aug 2016 at 10:49pm
Craneman's post about his axle nightmare has me a little worried.
Craneman View Drop Down
Direct Link To This Post Posted: 13 Aug 2016 at 9:54am
I have a lippert axel on our 2010 rp 174. I got the problem fixed my self. The plate that the backing plate bolts to was not welded on properly just had to put some shims in and all is well. My problem was with the brakes, are you haveing  problems with your axel??? If you have abnormal tire wear or some other indications of problems?..don't worry yourself to much about all the stuff you read about here on the forum. Pays to be informed  just keep up your maintenance and enjoy your trailer. Little problems just come and go
                  Moe
Jo and Gary
2010 174
2011 Ford 150
Direct Link To This Post Posted: 13 Aug 2016 at 10:35pm
No problems yet, only have aprox. 1500 miles on it so far.  I tow with a Tundra so I don't use the trailer brakes.  Tracks great and tows like a dream with the 5.7L out front.  I personally wouldn't tow it with anything smaller then a half ton truck or SUV.
Direct Link To This Post Posted: 13 Aug 2016 at 10:47pm
Just did a search on line, looks like The newer Pods have a Dexter Torflex axle.
Direct Link To This Post Posted: 14 Aug 2016 at 8:37pm
Multiple reasons to use the pod's brakes.  Far less wear on the more-expensive brakes on the TV.  Many states require it for a trailer with a gross weight above 3000 pounds.  Using only the trailer brakes is the only way to stop a bad sway situation.
Even with a full-sized truck I would never tow a trailer w/o using its integral brakes.
Direct Link To This Post Posted: 15 Aug 2016 at 9:42pm
Thanks for the advise.  I have a few things planned for next camping season.  1st is a 200 watt solar panel kit.  2nd is a sway dampner.  3rd will be a brake controller.  I read a few post about controllers when I first bought the trailer but was a bit confused as to which one would work the best and easiest. I've had several trailers, one being a tandem axle car trailer but none of them had brakes.
Direct Link To This Post Posted: 15 Aug 2016 at 10:03pm
Many like the Prodigy line.  I still use my original Prodigy, now they have the P3.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 15 Aug 2016 at 10:18pm
I've towed a lot of trailers without brakes too, big, heavy ones, and I still do, and I understand what you're saying about your 5.7L Tundra.  I didn't have a 7-pin connector or a brake controller when I picked up my RPod in Birmingham and towed it back to Nashville.  It's doable, no question.  But the best thing by far I've done since getting the RPod was get a brake controller and hook up the brakes.  Aside from, as Doug says, the law, and the general safety considerations, it takes a whole lot of the stress out of going down the road.
Direct Link To This Post Posted: 15 Aug 2016 at 10:25pm
I just did a little research and I like what I see about the
Tekonsha 90160 Primus IQ Electronic Brake Control.  I have a $100 gift card to Amazon burning a hole in my pocket, this is only $70 plus $12 for the plug and play wire harness.  I don't know what the laws are here in MA, maybe I should find out. Cry
