Page <1234> |
![]() Posted: 10 Jun 2016 at 9:33pm |
I've always liked your innovation for that.
I would set the fan to low, which will help. Someone else will need to step in with instructions for the digital thermostat. 1000 feet shouldn't make a noticable difference. Not until you get up several thousand feet. The rule of thumb is you lose 3.5% per 1000 feet, plus 1% for every 10 F above 60 F. So go to 3000 feet at 90 F and you've lost 13.5%.
When I had my Yamaha the fan would drop in speed when the compressor started, and I do believe the overload light would briefly light.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6431 |
I just purchased a Supco SPP6 seres hard start capacitor, which I will install as soon as I get a chance. While I have tried the AC with the Generac iX2000 generator successfully, I think this will help with the initial surge and make it work even better.
SNO4ME ![]() Senior Member ![]() Joined: 28 Sep 2013 Location: NW Wis Online Status: Offline Posts: 122 |
A year ago last fall we met a gentleman out in South Dakota. He had his 3k inverter Honda mounted in an aluminum tool box in his pickup. He had it all vented out and locked up. Very quiet and very secure. Nice set up if you have a pickup.
Bruce & Donna in the Sno Pod
(and Brewer too) 2011 RP 177 |
borjon ![]() Newbie ![]() Joined: 05 Jun 2016 Online Status: Offline Posts: 4 |
Thank you for your input. You have been very helpful. I think it might have been the heat. It was 100 degrees when we tried to run the gen. I'm not sure at this point if the general is going to be of much help when we camp in Arizona.
The Supco Hard Start Capacitor is headed back. Instead of helping, it killed performance. Without, the generator would surge as the load kicked in, but settle down and run. I installed the hard start capacitor and it immediately put the generator in overload, which cuts the current feed (I guess, to protect the generator's inverter from being damaged). I removed it, and the generator can run the AC again.
I had hoped this would be an inexpensive way to make the AC work easier with the generator. I was mistaken. I guess I would have to go with Dometic's Smart Start system, but I don't want to spend over $400 to do so. |
ron/roscoe ![]() Groupie ![]() ![]() Joined: 13 May 2016 Location: Hanahan, SC Online Status: Offline Posts: 84 |
Trying to find out the amp draw of the A/C on my 2016 Rpod 178. My Honda 2000 puts out about 17 amps, if I turn on just the a/c, will it work? I just don't want to smoke it!
Ron Rowland
JandL ![]() Senior Member ![]() ![]() Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
I have a 2012 RPod and the spec for my air conditioner are AC & fan start is 23 amps and run 16 amps
JandL
2013 Honda Ridgeline 2012 177 2 Paynes in a Pod |
Stephen, it should have helped, maybe you received a bad capacitor.
I was careful to wire it in parallel with the capacitor like I read. I
was really disappointed when it caused the generator to overload instead
helping the AC to start easier. I also figured that something must have been wrong with it. That's why it went back. Since the generator will start and run the AC, I will wait and see if I need to do anything. Hopefully, I won't need to.
Page <1234> |
