  New Posts New Posts RSS Feed: Hot water temp and Radio Panel
Topic ClosedHot water temp and Radio Panel
Direct Link To This Post Topic: Hot water temp and Radio Panel
    Posted: 02 Sep 2016 at 8:51am
On the water temp.. If it isn't scalding, I assure you, the bypass valves are wrong. NO ONE has ever complained that a properly set water heater was to cold.Most are worried about children scalding themselves, etc.
We don't have that same radio/cd setup, but I know the answers you have been given work.
psikes View Drop Down
Direct Link To This Post Posted: 02 Sep 2016 at 8:45am
Somewhere in the distant past someone came up with a button to turn the display off, not the backlighting but the display. I have full control of backlighting but the display is impossible to read because I can't remember how to turn it back on! Any one out there remember how to do that?
Thanks, Phil
2015 178 TV 2014 Honda Pilot Touring
Direct Link To This Post Posted: 14 Jun 2016 at 5:05pm
Upon reading the above posts, I consider myself fortunate in not having all those accessories.  Maybe sometime in the future we may consider an A/C unit but then we would either have to purchase a generator to power it or go to a campground with electricity.
Direct Link To This Post Posted: 14 Jun 2016 at 10:27am
I put in a "master" power switch to the Jensen unit, for the reason you describe. The unit only gets turned on when I want to watch a DVD.
It's easy to do, if you have a place in mind for a switch. I can give you details, if you wish to go that route.
Akula1 View Drop Down
Direct Link To This Post Posted: 14 Jun 2016 at 9:54am
Hi, I have a 2016 179, and we have plenty of hot water.
The Jensen radio lights can be a pain. We put up a tension rod with blackout curtains, and with the foil window coverings, even at high noon the bed area is pitch black.
2019 R-Pod 190
2019 Colorado LT
HawksPodder View Drop Down
Direct Link To This Post Posted: 13 Jun 2016 at 10:38pm
Thanks for ideas, I'll take a look.
ROdney
Direct Link To This Post Posted: 13 Jun 2016 at 9:28pm
I did mention that there is the "off" setting which turns the display light off completely. Adding a power kill switch should not be needed. Just keep pressing the down button repeatedly and it will dim until it reaches the off setting and the display light turns off.
We prefer the "1" setting as it is nice to have a little bit of light for those nighttime trips. We also added a curtain between the main area and the bed using a compression shower rod which is the old style with the spring inside. The new style of twist-lock does not work as it tends to not stay locked and falls down. Shutting the curtain allows one of us to go to bed earlier if the other decides to stay up a bit longer. It also blocks any stray light like that of the radio or the other night light we keep plugged in next to the door. Smile
Direct Link To This Post Posted: 13 Jun 2016 at 9:04pm
+1 with Techntrek
Direct Link To This Post Posted: 13 Jun 2016 at 8:54pm
I agree on #1, and you could add a switch to kill the radio power if the setting Stephen mentioned isn't dark enough (I believe someone here did that).
Direct Link To This Post Posted: 13 Jun 2016 at 5:35pm
1. Check the position of the bypass valve on the water heater. Ours gets up to 130 degrees, which is the limited temperature. If the bypass valve is open, it mixes hot and cold water and all you get is tepid water.
2. There is a way to adjust the brightness. On the left side of the display are two buttons for brightness. It will adjust from off, and 1-9 for brightness, with 9 being the brightest. Ours was set too high. I have it set to 1, which is the dimmest, and it is tolerable.
