  New Posts New Posts RSS Feed: Battery drain while In storge
Topic ClosedBattery drain while In storge
ron/roscoe View Drop Down
Direct Link To This Post Topic: Battery drain while In storge
    Posted: 10 Jun 2016 at 1:38pm
after about a week in storage, my battery indictor was about to 3/4 charged.  I bought a battery disconnwit switch from Amazon, sure fixed the drain issue.  Now I just turn the key on top the battery box to get power when I want it.  Cost less than $10.
Ron Rowland
CharlieM View Drop Down
Direct Link To This Post Posted: 10 Jun 2016 at 1:48pm
Battery disco switch is a good thing for storage. However, the battery will still eventually self discharge if left long enough. Check it every 3-4 months. And note the top light on the battery "indicator" only means the battery is being charged. The third light is still fully charged, just not being charged. From there down it's a crap shoot. The bottom light means you probably left the battery at home.
Direct Link To This Post Posted: 10 Jun 2016 at 6:32pm
What is a battery disco switch?  My switch simply breaks the negative wires to the battery.
Ron Rowland
Direct Link To This Post Posted: 10 Jun 2016 at 6:50pm
Disconnect switch.
Direct Link To This Post Posted: 10 Jun 2016 at 8:51pm
Lead acid batteries self-discharge 1-3% per day when they are warm, so you should recharge them overnight every 30 days.  During the winter months you can get away with 3 months.
osage View Drop Down
Direct Link To This Post Posted: 11 Jun 2016 at 9:37am
which switch is everyone using ?
Direct Link To This Post Posted: 11 Jun 2016 at 12:37pm
Check out the switches on Amazon, just ask for battery disconnect switches.  I also a 12 inch wire to complete the circuit.  I drilled three holes in the top lid of the battery, took about 30 minutes.  Don't forget to drill several holes in the bottom of e battery box to let rain water out.
Ron Rowland
AZ Hiker View Drop Down
Direct Link To This Post Posted: 25 Sep 2016 at 2:49pm
Is it best to disconnect the battery and take it out while the Pod is in storage?  I was thinking that it may be best to bring it home and connect to a trickle charger.  Thoughts?
R Pod 177
2011 Jeep Grand Cherokee Overland
1 Awesome Therapy Dog
Direct Link To This Post Posted: 25 Sep 2016 at 3:56pm
We take our battery out each winter and recharge it a few times during the winter.
Direct Link To This Post Posted: 25 Sep 2016 at 6:46pm
Our deep cycle group 24's are into their 6th year.  They are either left in the pod, unhooked, or taken out and left in our unheated garage in northern Michigan.  I will give them a charge in November with a trickle charger (2 amps) for 1 -2 days each and then copy this process again in April.  The first year I kept them in the basement of our house but Furpod told me that they would only discharge faster being in a heated environment, that the batteries would be better off in a colder area, so that is the advice I have followed and the batteries are still working well for us.
