Forum Home Forum Home > R-pod Discussion Forums > Dealer Reviews and Comments
  New Posts New Posts RSS Feed: Forest River Report Card
Topic ClosedForest River Report Card
Camper Bob View Drop Down
Direct Link To This Post Topic: Forest River Report Card
    Posted: 02 Mar 2016 at 6:56pm
My idea of fishing is to go to the local supermarket, head to the fish counter, and point and say, "that one."  I also have a problem watching baseball.  It, like fishing, to me is like watching paint dry.   Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
ron/roscoe View Drop Down
Direct Link To This Post Posted: 03 Jun 2016 at 7:29pm
On a 2016 Rpod 178, the tank level inductors do not work, after 5 days of camping, in grey water tank was still in empty.  Several showers and kitchen sink clean up.  On the night of the fifth day, the indicators went from empty to 75percent full.  Dealer in Myrtle Beach looked at the problem twice and said all as OK.  Help!
Ron Rowland
Direct Link To This Post Posted: 03 Jun 2016 at 9:15pm
Every camper I've owned it works for the fresh water tank, usually ok for the gray water tank, not at all for the black.  Fairly useless for the battery indicator even though it "works".
Direct Link To This Post Posted: 03 Jun 2016 at 9:24pm
The indicators are only relative. Empty can indicate empty, but it can also indicate less than 1/3 full. I have found that the indicator stays on empty for quite some time, jumps to 1/3, sometimes skipping to 2/3. Full is also only relative. When the full indicator lights, there is usually more capacity remaining. If you look under the R-Pod at the relative positions of the sensors (check to see if they are all there and the connections are tight), you will see that they are really clustered toward the middle of the tank. The linear distance between them is large, but the vertical distance between them is small. That vertical distance is the range in which the sensors work. It isn't much.
There is also the problem that any build-up in the tank (black or gray) can coat the sensors. If they are coated, they will not be able to detect the liquid level. It is common to add chemicals to the black water tank. I have seen additives for the gray water tank also. They are supposed to help keep the tank clean. I have not used them so far, but if I start having similar problems, I will probably try them.
