Page 123 4> |
Jeff Baurick ![]() Newbie ![]() ![]() Joined: 01 Jun 2016 Location: Eagle River, Ak Online Status: Offline Posts: 2 |
![]() Posted: 01 Jun 2016 at 8:26pm |
Is it possible to have a built in generator added to the R-pod 180, with inverter and auto start? Big enough to run the AC?
Jeff Baurick
Welcome to the group! Heck of a first question! I am sure someone in the group will be able to address it.
JandL ![]() Senior Member ![]() ![]() Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
I think it would be very expensive and take up a big part of the trailer. Just Google RV built in generator. I have had my trailer 2 years and have only used my generator one time. There are quite a few code requirements for a built in. They are not cheap, a Onan RV QG4000 (4.0kW) RV Generator is around $3000. It's 172 Lbs and 30"L x 19.7"W x 14.4"H
JandL
2013 Honda Ridgeline 2012 177 2 Paynes in a Pod |
WillThrill ![]() Senior Member ![]() ![]() Joined: 04 Jul 2014 Online Status: Offline Posts: 298 |
I really doubt that there would be adequate space anywhere to install one. These generators are not typically small units, and space is a premium in Pods. I suppose that it might be possible to have a very compact model installed in the rear storage unit, but that would eliminate most/all of the exterior storage you need for hoses, extension cables, etc. (ours is quite full). If you really want this type of unit, I would suggest you consider a larger travel trailer than an Rpod. Keep in mind, though, that built in generators only come stock in motorhomes, to my knowledge. I've never seen one in a travel trailer or 5th wheel.
2014 Hood River 177 2005 GMC Envoy XL |
See the referenced post from Marwayne. It can be done, but it's more of a built on rather than built in. Marwayne is a master craftsman and this is only a 2000 watt generator. This is not for the faint of heart. Additional searching will provide more details if you're interested.
EDIT: Corrected link http://rpod-owners.com/forum_posts.asp?TID=7495&KW=generator&PID=70657&title=generator#70657 |
Thanks guys. I think what I've learned is I will stick with my little Honda 2000 W generator. Will put in an extra battery and inverter so we can use the outlets. To use the AC, I will hope I can plug in at a full-service campground. Love this little trailer! We pull it with a Toyota sienna.
Jeff Baurick
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6431 |
There is something wrong with the link you provided. It takes me to a new post page that says I don't have permission to post. Please re-do the link so that it goes to the intended target. |
You are correct. Try this one: http://rpod-owners.com/forum_posts.asp?TID=7495&KW=generator&PID=70657&title=generator#70657 |
That works. Thanks.
Welcome. Another consideration with having a generator on the camper itself is vibration and noise. For that reason I mounted my generators (first a Yamaha and then a Honda) on a cargo tray on the front of the TV. I barely hear it and definitely don't feel it.
Page 123 4> |
