  New Posts New Posts RSS Feed: Deep cycle batteries
Topic ClosedDeep cycle batteries
Direct Link To This Post Topic: Deep cycle batteries
    Posted: 10 May 2016 at 8:59pm
How will you camp off-grid?  Boondock often and for long periods of time?  Just for the weekend every once in a while?  If the later, your best bet for your money is the Everstart marine DC-series at Walmart.  I used to maintain a bank of 16 of them and it was the best $/amp bang for the buck for lighter use.  No reason to go to two 6 volts for this.
If you will do it often and long, go for a true deep-cycle like Trojan.  Two 6 volt batts.
Direct Link To This Post Posted: 10 May 2016 at 7:56pm
I went the dual six volt deep cycle batteries purchased at our local Batteries & Bulbs (AKA Batteries Plus) store. They are wired in series to deliver 12 volts. If you go dual 12 volt, then those need to be wired in parallel or else you will wind up with 24 volts instead of the 12 you need.
Mountainrev View Drop Down
Direct Link To This Post Posted: 10 May 2016 at 6:53pm
Are you sure you ruined the battery?  The fuse is there so that if you do reverse the polarity, you don't damage the battery or your electrical system.  If you blew the fuse, your battery should be fine.  If you haven't done it already, you can take it to any auto parts store and have them check the battery for free.  I'd do that before spending money on a new one.  If it is shot, yes, any group 24 battery sold as "marine/deep cycle" would be fine.  If you have a Costco membership, they seem to have the best prices on them, and they're usually in stock.
If you are looking for more amp hours than the "marine/deep cycle" battery it came with (which undoubtedly isn't a true deep cycle), two six volt golf cart batteries seems to be the way to go.  I have two 12 volt "deep cycles" on ours, and that has proven to be plenty of amp hours for our needs (3 days or so off grid).
2014 177
johnmaci View Drop Down
Direct Link To This Post Posted: 10 May 2016 at 6:35pm
Lifeline AGM Battery is supposedly the gold standard.
Here is a good review:
http://www.doityourselfrv.com/best-rv-battery-choosing-reviews/2/
podrunner View Drop Down
Direct Link To This Post Posted: 10 May 2016 at 6:04pm
Check out Exide Nautilus series.  They offer both a dual purpose and a deep cycle.  I bought mine at a "Home and Ranch" store.  I believe Home Depot sells them as well.  BTW buy a size 27, just a bit more $, and quite a few more amps.   Good Luck..
2010 R Pod 151
2017 4runner
2006 Honda Metropolitan
Happy Tripping View Drop Down
Direct Link To This Post Posted: 10 May 2016 at 5:29pm
I am afraid that I killed my dealer-provided deep cycle/marine battery by using it instead of shore power. I put the cables on with the wrong polarity and the fuses blew without me knowing it. That night the trailer lights suddenly became very dim.
We're off to a cold Yellowstone next week and we'll need the furnace. The local battery places (Walmart, Sears) are tremendously ignorant about RV batteries, even worse than me. I don't want the complexity of golf cart batteries. Gander Mountain MAY have what I need. Specifically, what do I tell them to get a proper replacement -
Will  "Group 24 deep cycle marine/RV battery, and not a starter battery" do the job??
I'd really prefer a pure "deep cycle" non-marine one, but when I say this, no one around me knows what I'm talking about. Are there any specific numbers that I should be using??
Thanks for any help.
