Page <1 234 |
![]() Posted: 22 Jun 2015 at 8:25pm |
The question that needs to be asked in this discussion. What came first; the chicken or the egg?
OnTheRoad6 ![]() Newbie ![]() ![]() Joined: 20 Feb 2016 Location: Fort Myers FL Online Status: Offline Posts: 6 |
Someone please help this ignorant (!) trailer newbie! I guess, based on what I am reading, that I should disconnect the battery on my Pod as it is stored where I don't have electricity. But I've also read several opinions for disconnect -- is it negative first, positive second, or positive first, negative second, or just positive or just negative? ![]() I won't do the switch option now after spending a ton of money to get the breaking system installed. I can't do it myself so have to pay big bucks for everything -- this RV thing gets expensive! It's okay and totally worth it ![]() Thanks for any help you can give me.
You only need to disconnect one lead. Disconnect which ever one you want. It's a Ford-Chevy, Blondes-Brunettes argument about which is better. I do the positive. |
If you store without electricity you should disconnect the battery. It's only necessary to disconnect one side. Simply removing the lead with a wrench works just fine and the price is right. IF you ever might plug in the Pod before reconnecting the battery a weak argument can be made to disconnect the negative side, otherwise disconnecting the positive is customary. That said, it really makes little difference.
Unless you disconnect the battery while the pod is plugged in, then the loose positive connection could short to the frame. My personal reason for going with positive.
However, if a loose negative contacted the frame, there would be no issues whatsoever. That is another reason for going with negative.
Doug, I'm missing your point here. The possibility of the positive lead contacting the frame when the Pod is plugged in was my weak concession to disconnecting the negative. Otherwise I agree positive is per convention. |
Page <1 234 |
