Page <123> |
Author | ||
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6437 |
![]() Posted: 09 Mar 2016 at 9:48pm |
This is the one I purchased (pictured above):
http://www.amazon.com/gp/product/B005DUUL9W?psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s0 It is supposed to be water tight. I anticipate it giving good service. |
Idaklee ![]() Groupie ![]() ![]() Joined: 18 Sep 2015 Location: Minnesota Online Status: Offline Posts: 46 |
Stephen H, this is what my dealer offered me. But now I see the sign saying they changed their hourly rate to $130 an hour, I guess I'm going to pass!! But thanks to everyone...I learn something new every time I visit!
Marcia from MN
13 177 R Pod 06 Dodge Grand Caravan Max, Gracie & Greta |
That is excessive! It really is not a difficult job to install one. I looked for a place that would have adequate clearance between the top of the battery and top of the lid for me to mount the switch inside the cover. I used a drill with a hole saw to drill an appropriate size hole in the lid. I used stainless steel screws and locknuts to fasten the switch to the cover. Wiring is simple. Remove the cable from the negative terminal. Mount it to one post of the switch. Use another cable (your local auto parts store should have an appropriate one) to run between the other post of the switch and the negative terminal of the battery. Put cover back in place and you are done. Nothing is beyond the abilities of the average person to do. If you can handle a screwdriver, wrench, and drill, you are more than capable of doing this yourself. If you don't have the tools, you could buy them and still be way ahead of paying the dealer to do this. In any case, a cordless drill is a handy thing to have. Team it with the appropriate socket and adapter, and you have a fast and easy way to lower/raise the stabilizer jacks. That alone makes the purchase of a cordless drill worthwhile. ![]() |
Hmmmm, that does seem fairly simple! I just might give it a try! Thanks so much!
Marcia from MN
I will probably do this eventually. It keeps everything sealed up while disconnected and is more reliable than a switch. |
JohnBG ![]() Senior Member ![]() Joined: 14 Apr 2015 Location: Deltona, FL Online Status: Offline Posts: 190 |
Why the negative? With the positive connected there is still the chance you could accidentally ground something in the system causing sparkage.
2010 R-Pod RP-171
2010 Honda Ridgeline TV |
Yes, but if the loose positive makes contact with the frame, you'd get much worse than sparkage, i.e. a short circuit. |
See post #6 here: http://www.firehouse.com/forums/t129702/
See also this link: http://www.popularmechanics.com/cars/how-to/a1454/4213127/ The rule of thumb for working on batteries is always disconnect negative first, then positive. Always connect positive first, then negative. That is why it makes sense to put the switch on the negative terminal. It is more a safety issue for when one is working with wrenches around a battery. If you read the first link, you understand why. |
I go with positive (NHRA does too). Long discussion on it here: http://www.rpod-owners.com/forum_posts.asp?TID=6306
When I saw this topic resurrected I swore I wouldn't open my mouth .............................and I won't ![]() |
Page <123> |
