Page <123> |
Author | ||
![]() Posted: 10 Mar 2016 at 5:18pm |
Yes, but if the loose positive makes contact with the frame, you'd get much worse than sparkage, i.e. a short circuit. |
JohnBG ![]() Senior Member ![]() Joined: 14 Apr 2015 Location: Deltona, FL Online Status: Offline Posts: 190 |
Why the negative? With the positive connected there is still the chance you could accidentally ground something in the system causing sparkage.
2010 R-Pod RP-171
2010 Honda Ridgeline TV |
I will probably do this eventually. It keeps everything sealed up while disconnected and is more reliable than a switch. |
Idaklee ![]() Groupie ![]() ![]() Joined: 18 Sep 2015 Location: Minnesota Online Status: Offline Posts: 46 |
Hmmmm, that does seem fairly simple! I just might give it a try! Thanks so much!
Marcia from MN
13 177 R Pod 06 Dodge Grand Caravan Max, Gracie & Greta |
That is excessive! It really is not a difficult job to install one. I looked for a place that would have adequate clearance between the top of the battery and top of the lid for me to mount the switch inside the cover. I used a drill with a hole saw to drill an appropriate size hole in the lid. I used stainless steel screws and locknuts to fasten the switch to the cover. Wiring is simple. Remove the cable from the negative terminal. Mount it to one post of the switch. Use another cable (your local auto parts store should have an appropriate one) to run between the other post of the switch and the negative terminal of the battery. Put cover back in place and you are done. Nothing is beyond the abilities of the average person to do. If you can handle a screwdriver, wrench, and drill, you are more than capable of doing this yourself. If you don't have the tools, you could buy them and still be way ahead of paying the dealer to do this. In any case, a cordless drill is a handy thing to have. Team it with the appropriate socket and adapter, and you have a fast and easy way to lower/raise the stabilizer jacks. That alone makes the purchase of a cordless drill worthwhile. ![]() |
Stephen H, this is what my dealer offered me. But now I see the sign saying they changed their hourly rate to $130 an hour, I guess I'm going to pass!! But thanks to everyone...I learn something new every time I visit!
Marcia from MN
This is the one I purchased (pictured above):
http://www.amazon.com/gp/product/B005DUUL9W?psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s0 It is supposed to be water tight. I anticipate it giving good service. |
We have had a couple owners have switch failures, usually a $3 switch that looks pretty much like mine. But Mine is an actual HELLA kill switch, going into it's 6th season, on it's second set of batteries and box, in a state that gets 60 inches of rain annually. No issues yet. |
kylekai ![]() Senior Member ![]() Joined: 06 Aug 2014 Location: San Diego Online Status: Offline Posts: 139 |
I did exactly that, but about 2 months later I had no power in the r-pod. After an exhaustive search, it was determined that the switch failed. Removed the switch, and back to normal. Maybe it got wet and rusted, I don't know. Something to keep in mind.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3331 |
I am with you Charlie.
Page <123> |
