Forum Home Forum Home > General Camping > Cook'n With Gas > Gas/electric stove
  New Posts New Posts RSS Feed: Cooking on stove top
Topic ClosedCooking on stove top
Dawg Pod View Drop Down
Direct Link To This Post Topic: Cooking on stove top
    Posted: 24 Nov 2013 at 9:28am
We purchased a cast iron diffuser for the gas burners on the rPod because we found the flame level of the burners very hard to control, either blast or off essentially. The diffuser worked like a charm, providing very even heat and slowing the cooking process. No more burned corn cakes for us!
g4royce View Drop Down
Direct Link To This Post Posted: 17 Dec 2013 at 12:10pm
Which one did you get?  We used to have the Norpro ones in aluminum but found that they warp over time.  We now use a cast iron one and it stays flat.
ChaiPod
2009 RP152
2011 Hyundai Santa Fe 3.5L V6
Online Status: Online
Direct Link To This Post Posted: 15 Jan 2016 at 8:02pm
Okay, how about toast? We have an old stove-top toaster that is a perforated metal circle with collapsible wires to hold the bread or other item. The problem is that if we use it, the smoke detector will go off. Unfortunately, our R-Pod lacks a vent hood to take care of this. So, how does one make toast and save his/her hearing? (This is when AC is not available to power an electric toaster).
Direct Link To This Post Posted: 15 Jan 2016 at 8:57pm
You pull the battery out of the smoke detector, just like everybody else does when cooking... Wink
Some owners have used a shower cap, placed over the detector while cooking also.
Direct Link To This Post Posted: 15 Jan 2016 at 9:19pm
A shower cap is one option. I'll have to look for one. Eventually, I'd like to figure out a way to add a hood to the stove area, even if it only was one that used filters and recirculated the air inside instead of venting it outside.
Direct Link To This Post Posted: 15 Jan 2016 at 9:23pm
I sometimes open the window behind the sink and stove and then turn on the FF.. it does a great job.. But the space is so small, it doesn't take much to reach whatever concentration is needed to set the thing off..
Direct Link To This Post Posted: 16 Jan 2016 at 11:35pm
Turn on the bathroom fan.
