  New Posts New Posts RSS Feed: battery maintenance?
Topic Closedbattery maintenance?
loampey View Drop Down
Direct Link To This Post Topic: battery maintenance?
    Posted: 30 Dec 2015 at 6:12am
I leave my pod on shore power year round and it is not an issue. If that is not an option put them on a smart charger and it will keep them up and should not overcharge. Go to a web sight called batterystuff.com and you can find out any thing you would ever want to know about batteries of all kinds.
Direct Link To This Post Posted: 28 Dec 2015 at 9:56pm
Cold will preserve battery life, so I recommend leaving them outside.  Just charge them every 30 days (disconnecting from the pod between charges), or leave the pod plugged in.  More accurately you need to do it no longer than every 30 days when it is warm, but you can go 2-3 months in the dead of winter depending on where you live in California.
Direct Link To This Post Posted: 27 Dec 2015 at 10:30pm
I would remove the negative terminals since the carbon monoxide detector unit will slowly drain the battery.
Robwid View Drop Down
Direct Link To This Post Posted: 27 Dec 2015 at 10:29pm
I also have two six volt batteries because we mainly dry camp.  During the winter I disconnect the neg terminal for storage. I reconnect and plug my pod into shore power a couple times during the winter to top the batteries off.  This will be our fifth season with the original batteries and they are still going strong.
Rob
2012 HRE 177
2010 Toyota Tacoma
Direct Link To This Post Posted: 27 Dec 2015 at 10:27pm
Hi Carol
I have 2 deep cycle 12 volt batteries since I dry camp a lot.  During the winter in northern Michigan I remove both batteries and put each one on a 2 amp slow trickle charge in October - this takes about a day each for the charge to complete.  I then keep them in my basement (heated) throughout the winter.  They were purchased in 2011 and are still in excellent condition.  In mid-April I give them another trickle charge (usually takes about 6-8 hours for each battery) and then re-install them on my 177.
cgarb View Drop Down
Direct Link To This Post Posted: 27 Dec 2015 at 8:18pm
 We have new 6-volt marine batteries, replacing 12V original equipment.  Does anyone have advice on how long and how often should we charge them?  And if we don't go camping for a couple of months, should we disconnect the negative terminals?
Thanks!
Carol
177 HRE rpod
2014 Honda Pilot
