Have You Done Any Mods? |
Page <1 2829303132 52> |
Jobwabe ![]() Newbie ![]() ![]() Joined: 15 Oct 2015 Location: Susanville Online Status: Offline Posts: 17 |
![]() ![]() ![]() ![]() Posted: 17 Dec 2015 at 12:05pm |
And one more. Sorry for the picture duplicates: uploads/4717/podundermodA.JPG
So this is the airflow mod underneath?
Yes, it gave quite the fuel savings-22%-over 8000miles. Remember that I have the trailers a-frame floored as well but this was done before this other air flow mod so can't know if it (the a-frame job)was involved in the fuel savings.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6452 |
We just completed the first leg of our maiden voyage. Two modifications I made which have been really useful are to add a 12 volt outlet and a shelf.
The 12 volt outlet was easy. I got a socket and installed it, connecting in to the wiring for the heater. The shelf was a bit more challenging. I also used the wooden Allen Roth shelf from Lowes and L brackets. However, instead of drilling into the walls, I used the L brackets to hook behind the valence on each side and then used heavy-duty command strips to fasten to the wall. I also installed a bolt at the end of the support boards and drilled a hole in each end of the shelf to fit over the bolt. It prevents the shelf from sliding. I have found that so far, this shelf travels well. I will try to add pictures later. I appreciate the picture of the underbody modifications. I hope to do so after we return from this trip. Any increase in mileage would be greatly appreciated. |
Good job. What I have recently done for books and magazines is to mount what looks V-like (cross section of) clear plastic file holders that I bought from Office Depot. These came 3 in a set. I've got 2 side by side mounted over/on that mini shelf thing that is right at the wall end of the table, using small screws and silicone. Then the 3rd one mounted the same way over the kitchen-side wall but over the window above the bed. This one for night reading. Both books and travel brochures and maps store well in those. And a real easy mod. Note that we have a 177 model Pod. Have great travels!
RoadToad ![]() Groupie ![]() Joined: 18 Nov 2015 Location: Ninilchik Online Status: Offline Posts: 46 |
2015 RP179 TWIN PROPANE TANKSTWIN BATTERIES MIRROR ON CABINET DOOR BY EXIT DOOR 60" SPICE RACK OVER REAR WINDOW- COROPLAST & ZIP TIES PAPER TOWEL DISPENSER BY EXIT DOOR/KITCHEN AREA SKIRTING AROUND POD FOR COLD WEATHER CAMPING TV MOUNT THAT TILTS UP & DOWN TIE DOWN FOR TV ANTENNA |
2015 RP179
I would love to see pix of this. Is there anyway to post pictures?
2015 RP179
Press Post Reply at the bottom-right of the page Then press the little tree picture.
Jpntime ![]() Groupie ![]() Joined: 28 Jan 2015 Location: Nv Online Status: Offline Posts: 70 |
Love to camp
2014 171 |
Well, I had mentioned a couple of mods. Since then, I have done a whole set of them and have the pictures to prove it! I will be adding more, but you should be able to see them by using this link:
Edit: All pictures are now in my ouR escaPOD mods. the link is below in my signature. Pictures show the following mods: 1. shelf bracket (back and top views used to mount the shelf above the bed in our R-Pod 179. 2. Completed shelf showing how it sits on the bracket. The bolt goes through a hole in the end, locking the shelf into place. With our cross-country trip, the shelf rode just fine. The brackets are currently held in place with the L-brackets and heavy duty command strips. One of these days, I will probably change the command strips to moly bolts. 3. Vinyl post (5") cut and strapped in place to hold folding ladder. Since the R-Pod did not have full-width storage, this was needed since I could not fold the ladder lengthwise to fit in the stock storage area. I also put a cap on the end to keep the ladder from damaging the wall. I am trying to figure out the best way to cap the other end. It will probably involve a Velcro (or equivalent) strap. 4. 1" Foam Insulation panels (from Home Depot) cut to fit and wedged in above the stowage compartment. 5. Moved panel from under-bed stowage area, replaced with new panel and constructed frame to make a usable stowage cabinet under the bed that would be separate from the furnace. Added quarter-round molding to cover rough edge from breaking the panel loose. It does not quite match, but under there, who will notice. ![]() 6. Constructed frame and panels to convert wasted space on right-side next to closet into usable storage space. 7. Added angle molding to edge of bed platform to cover raw edges (and to keep me from getting more splinters from it). 8. Added pull-ring to back side of bed platform to help lift it. I had previously put hinges between the two platform pieces. I had to trim the edges a bit to clear the window hardware, but now I can get to the water pump easier if needed. 9. Added 12 Volt circulating fan to help move the heat from the furnace out to the rest of the R-Pod. It really does make a difference!. ![]() 10. Built framework and box to convert wasted space in dinette end nearest refrigerator into usable space. It isn't big, but every little bit helps. 11. Modified partitions underneath stove on bottom and top to reclaim some wasted space. 12. (not shown) Added layer of 1/4" plywood and bracing to repair cabinet shelf to right of sink which cracked when we hit a large bump and the electric pressure cooker that was on it bounced a little too hard for the flimsy plywood that was there originally. It is still there, just reinforced. 13. (not shown) Added insect screening to refrigerator vents to keep nesting insects (mud daubers, etc.) out. We found out about that when our new trailer had a refrigerator problem (we only had it a week) and when we took it back to the dealer, mud daubers were the problem. They tried to suggest that it could have happened after we picked it up, but this was December, not July, so I don't buy it. 14. Constructed battery lockdowns to make it more difficult for someone to walk off with our batteries. Works well now that I finished tweaking it. 15. This is a fit and finish issue. I saw that the stove had four holes for screws to attach it to the counter. These were not installed and I noticed that the stove was not staying in place properly. It now is screwed down as it should be. Other fit and finish issues were the failure of the factory to properly tighten the drain fixtures for the kitchen sink. This led to the sink leaking water and damaging two cookbooks which were in the drawer below. ![]() The last one I will mention is the panel under the refrigerator. What genius thought that three screws into soft aluminum framing were adequate to hold the panel? It now has anchors in the aluminum frame and decorative caps to cover the fender washer and screw heads. These should not loosen as we travel. If they do, I will try something else. Any suggestions? That is enough for now. I may think of more modifications to make. |
