Page <1234> |
Author | |||
![]() Posted: 02 Dec 2015 at 9:55pm |
FR likes to infer it is an advantage, but we've all learned that isn't true. Once you get above 50-55 mph you hit a brick wall.
No need to buy premium until the tank that you will tow with. The variable valve and knock-sensing systems are constantly checking for and adjusting for multiple variables including the fuel.
I always throw up a big warning for 3500 pound rated vehicles that will be towing the heaviest pods like that one. Pack light and do not tow with any of the tanks full. Maybe a few gallons of water to wash hands and flush while you are on the road but that's it. Rule of thumb is with your stuff and a full tank of water you'll add 1000 pounds, and you need to stay below that. Put some heavier things in the TV if you can.
Vann,
Thanks. We go to Chapel Hill when my wife has appointments at the UNC Medical Center. It will be good to compare notes. Edit: I just looked at some of your mods. I have some ideas, but will need to get the R-Pod first and see what ideas I can use. I already know I need to add a 12 volt outlet. I also would like a shelf above the bed to hold things like my CPAP machine, our cell phones, etc. I need to find out how to mount a shelf. |
We are also in North Carolina-Chapel Hill actually. We also bought from Country Roads RV-Jeff Zimmerman was very fair and honest with us. Tell him I said "Hello" when you pick up your new unit.
We also looked at Casita and Scamp and decided on the RPod-so glad we did. Its been a great trailer for us. Let me know if I can help with local questions. There is a lot of great info on this forum-read it and ask questions. travel safe Vann |
With the factory towing package, the frontal area consideration is 30 sq. ft. The base vehicle area is 20 sq. ft. Ford's towing guide says that exceeding the frontal area specs may decrease performance of the tow vehicle. While the R-Pod specifications indicate that the frontal area is > 30 sq. ft, the shape should help. It isn't a vertical slab like some of the other options we looked at such as the Starcraft AR-One or the KZ Spree Escape, which while not vertical were much more so than the rounded shape of the R-Pod. This seems to be the best option for now, especially since we just upgraded the Escape and are in no position to trade vehicles.
I will certainly keep an eye on things and report how it works once we pick it up and get some real-world experience. Ford does recommend using premium gasoline when towing. I have been filling with premium in preparation for picking it up so the engine can develop the maximum power instead of being down tuned for regular gas. I think if I can watch the weight, that will also help. The RP-179 has a dry weight of 2,630 lbs. If I can keep the loaded weight under the 3,500 lbs (well under, I hope), that should also help. |
Old Dingo&Mrs.Dingo ![]() Senior Member ![]() ![]() Joined: 07 Jul 2012 Location: Tarentum, PA Online Status: Offline Posts: 138 |
Stephen, Ford Motor Company has a tow "rating", for their vehicles, that refers to total frontal area as well as weight, you might want to look at it before you pull the trigger. I considered a Escape, I really liked the "high tech" aspect of the EcoBoost, but went home with a hemi powered Grand Cherokee instead.
Old Dingo and/or Mrs. Dingo
181G 2013 Jeep Grand Cherokee |
Unfortunately, I did lose money.
![]() I contacted the dealer (Country Roads RV Center in Lexington, NC). It is not too late to get the battery upgrade, and the preliminary quote I got sounds reasonable. This way too, I should get the proper size cases for the six-volt batteries. I'm glad I didn't wait until we got there to pick it up to ask. ![]() |
Welcome. Hopefully you didn't lose any money on the Casita that wasn't. If you already had the 12 volt battery I would say just get another like it and use it for the next 5-6 years.
Thanks. I would not have thought about that. I'll contact them soon as I finish this message.
Using two 6V golf cart batteries will provide 30%-40% more capacity than two Gp 24 twelve volt batteries. The battery is usually a dealer installed item and is the cheapest one from his stock. If you can contact the dealer before you pick up the camper you may be able to negotiate a swap for two good 6V golf cart batteries. Many dealers supply Interstate batteries and they make a good golfer. He should give you some credit for the 12V battery you paid for and you don't have to dispose of the new/unused battery. In any case make sure the rack on the RPOd will accomodate two 6V golfers with cases.
Thanks for the advice. I would like to go the 6 volt route, but will initially need to go with a second battery like the first. If batteries hold overnight, that will be adequate for the first trips. While we are at our daughters' houses, we should be able to hook up to AC and while we are on the road, they will get a T.V. charge during the day.
My CPAP does use 12V. The power brick supplies that 12V but battery supply should be fine as long as I don't try to power the humidifier also. The concern, of course, is the furnace. If we keep the temperature setting low, it should reduce the power needed We will just have extra blankets. Other than that, we will need to charge cell phones, but again, that can be done during the day while we are travelling. If I were to get two 6V batteries, what could be done with the 12V battery that will come with the R-Pod? I don't have a boat with which to use it. It would be too good to recycle. |
Page <1234> |
