Page <1 3456> |
![]() Posted: 24 Sep 2015 at 8:26pm |
For your average camper I always recommend 30-60 minutes every other day. That usually keeps the battery in the 50-80% range. Obviously not enough for a Field Day. I would go with once a day and pay attention to when it goes to idle. You could also put a Kill-A-Watt or clamp-on-ammeter in the equation to give you hard numbers.
I finally put my Salem on the Kill-A-Watt. After 25 hours it used .48 kw, so about 20 watts. Battery already charged and nothing on. Hopefully my suspension parts will all be in soon so I can fix the leaf spring and I'll check on the usage again then.
Final update from my Kill-A-Watt. After 6 days it averaged just under 20 watts, or a little over 14 kw per month.
Thanks Doug. I kinda got distracted with with camping and stuff so didn't keep kill-a-watt plugged in more than a day or so. Bottom line is I don't think it should be a big (energy) concern keeping plugged in 24/7. Finally building a new garage so looking forward to 30A hookup. Just gotto figure how I'm gonna hang that 60 inch plasma TV in the manpod!
Arrrr-arrrrr-arrrrr!
lonestarforever ![]() Newbie ![]() Joined: 14 Oct 2015 Online Status: Offline Posts: 3 |
![]() I am new to the R-Pod forum and glad you guys have brought this up. My last RV, a 28' Dutchmen, had a three stage charger. If I left the shore power plugged in 24/7/365, the batteries would go dead every other year. Reason being is a three stage charger has a "float" or trickle charge that never really shuts off. Even topping off the water level, the batteries would eventually end up cooked. I ended up installing a 4 stage smart charger that actually shuts off when the batteries are charged. Folks on this forum seem to think it's ok to stay plugged in 24/7/365. Are the R-Pod 3 stage chargers smart enough to keep from cooking the batteries? I'm curious because I wired in 30 amp service to my house and would LOVE to just keep the R-Pod plugged in. Oh, it's a 2015 RP178. |
Welcome. Sounds like your converter wasn't working right, most modern converters have a proper 3-stage charger that won't overcharge.
Great! Thank you for your reply. I was hoping the newer 3 stage chargers were smart enough to not cook the batteries.
Thanks! That's gives me a lot more confidence in the newer style chargers. My last RV was a 98 model. I think back then 3 stage chargers were notorious for trickle charging your batteries to death.
Page <1 3456> |
