  New Posts New Posts RSS Feed: Dometic AC E4 Error 2015 RPod
Topic ClosedDometic AC E4 Error 2015 RPod
kymooses View Drop Down
Direct Link To This Post Topic: Dometic AC E4 Error 2015 RPod
    Posted: 08 Oct 2015 at 9:17am
Glad to hear you fixed it. The thermostat runs from the 12 volt system so the only way to remove all of the 12 volt power sources is to unplug the pod and disconnect the battery. That is what kymooses meant by "complete shutdown of power".
Yes, very sorry to have not clearly stated it that way.  That was what was rattling around in my head.  Wink
Direct Link To This Post Posted: 06 Oct 2015 at 2:30pm
Irish Tom View Drop Down
Direct Link To This Post Posted: 06 Oct 2015 at 1:31pm
Unplugged the RPod and it did not help.
Had to disconnect the battery and unplug and it cleared the E4 error message.
Thanks,
Irish Tom
Direct Link To This Post Posted: 05 Oct 2015 at 10:12am
Sometimes it really is just a glitch of the t-stat.  A complete shutdown of power to the entire camper and then plugging back in will sometimes just clear the error code.
This is the error code message for E4
Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
can continue to operate.
Direct Link To This Post Posted: 04 Oct 2015 at 5:04pm
Turned on my AC and am getting the E4 Error Message on my thermostat.
I have a 2015 RPod 178 and a 3 button thermostat.
Is this a warranty issue or can it be cleared.
Thanks,
Irish Tom
2015 RPod 178
