GLBCamper
Topic: battery power? Posted: 08 Sep 2015 at 12:03pm |
Another battery related question. I keep the pod plugged into shore power when storing at home and tow with a charge line, but when I get to a dry camping site and disconnect from the TV the battery indicator on the wall panel shows 2/3 (3 dots). I know the panel lights aren't very specific but it seems like it should read full (or 4 dots).
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
WillThrill
Posted: 08 Sep 2015 at 12:33pm |
Originally posted by GLBCamper
Another battery related question. I keep the pod plugged into shore power when storing at home and tow with a charge line, but when I get to a dry camping site and disconnect from the TV the battery indicator on the wall panel shows 2/3 (3 dots). I know the panel lights aren't very specific but it seems like it should read full (or 4 dots). |
As said before, don't put much stock in what the onboard battery indicator says. The FAR better way to measure a battery's capacity is with a voltmeter. You can install a permanent voltmeter as many here have done. I installed a 12v socket very close to the junction box and just plug in an Innova voltmeter into that to assess the battery. The back of the voltmeter even tells you what voltage corresponds to what percentage of capacity the battery is at. Even more simple, you can get a 12v socket that just clamps onto the battery outside and plug the Innova voltmeter into that, but that requires going outside.
2014 Hood River 177
2005 GMC Envoy XL
Posted: 08 Sep 2015 at 1:07pm |
Plus, if you tow with the fridge on DC mode, most TV wiring (including factory-installed wiring) isn't large enough to handle the 10-11 amp load. So you end up discharging your camper battery while you tow - and if you tow more than a few hours your food will start to warm up once the pod's battery has run down. Always use propane mode on the road, it is the best way to avoid battery and fridge issues. Often it means less "fiddle factor" too.
CharlieM
Posted: 08 Sep 2015 at 1:25pm |
Another battery related question. I keep the pod plugged into shore power when storing at home and tow with a charge line, but when I get to a dry camping site and disconnect from the TV the battery indicator on the wall panel shows 2/3 (3 dots). I know the panel lights aren't very specific but it seems like it should read full (or 4 dots). | Good words from WillThrill and Techntrek. The OEM 4 light status panel is essentially junk. It is only really accurate if no lights light. That means your battery fell off on the way. The top light will light when the battery is being charged. Normally the third light will light with a fully charged battery, but it doesn't really mean you only have 2/3 or 3/4 charge. Don't be concerned. The best solution is a digital voltmeter or hydrometer as said.
David and Danette
Posted: 08 Sep 2015 at 3:35pm |
I think that most tow vehicles provide about 10 amps. to trailer does that sound about right.
2014 Ram 1500 Quad cab
WillThrill
Posted: 08 Sep 2015 at 7:06pm |
Originally posted by David and Danette
I think that most tow vehicles provide about 10 amps. to trailer does that sound about right. |
Generally, no. Most TVs are only pushing 5-8 amps to the trailer. This can obviously be increased with larger gauge wire, larger fuses, and the changing of any diodes, but honestly, the big reason people would do so is to run the refrigerator on electric power while towing. This can easily be accomplished by running the fridge on propane instead.
2014 Hood River 177
2005 GMC Envoy XL
David and Danette
Posted: 08 Sep 2015 at 7:46pm |
Sounds like propane as has been said is the best option for refrigerator. The trailer with everything else that's using amperage while towing 5-8 amps. doesn't leave much for refrigerator. The trailer battery would need to make up the remaining amps. needed.
Posted: 08 Sep 2015 at 8:57pm |
Posted: 08 Sep 2015 at 9:21pm |
Sounds like propane as has been said is the best option for refrigerator. The trailer with everything else that's using amperage while towing 5-8 amps. doesn't leave much for refrigerator. The trailer battery would need to make up the remaining amps. needed. |
Essentially. With 12 gauge wire you get a nearly 10% voltage drop, or about 12.7 volts. That isn't enough to maintain a maintenance charge on the camper battery if it is fully charged to start. If it is low then the voltage crashes and your food gets warm.
WillThrill
Posted: 09 Sep 2015 at 12:54am |
Many people report that their battery is drained in as little as five hours when running the refrigerator on battery power.
2014 Hood River 177
2005 GMC Envoy XL
