  New Posts New Posts RSS Feed: Min generator size
Topic ClosedMin generator size - Event Date: 21 Aug 2015
ToolmanJohn View Drop Down
Direct Link To This Post Calendar Event: Min generator size
    Posted: 23 Aug 2015 at 3:27pm
Originally posted by Pilotwh
Lot of great info from all. Thanks.
Hey toolman where did you put the marine switch. I have boats with them but they came that way.
Probably gonna take a serious look at the Champion. Right now Costco has it for $799.
I mounted the switch inside a NEMA 4X fiberglass outdoor rated box (sealed lid), cable glands with outdoor rating UV rating, but I did drill 4 small hole sin the bottom, just in case water somehow got into the enclosure it can drain easily. The switch is IP67 marine rated, although this is the second one since 2012, the first imploded (broken internally and ceased to function).
 I made the custom battery cables. Basically, the switch has three connections. Each battery positive terminal  goes to a switch terminal (Battery 1 and Battery 2), the last switch terminal goes to the original camper positive.  The batteries (both) negative terminals are wired together to the original camper ground (white). I can use battery 1, or battery 2, or both in parallel, or both off.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
jstrenn View Drop Down
Direct Link To This Post Posted: 23 Aug 2015 at 3:57pm
Amazon has it for $799 also.  Can avoid tax too depending on where you live.  Free shipping too if your a prime member
Direct Link To This Post Posted: 23 Aug 2015 at 9:36pm
I recommend 3000 watts if you will camp at a higher altitude (Yellowstone is over 8000 feet).  You'll lose 3.5% of your power for every 1000 feet above sea level, and 1% for every 10 F above 60 F.  So you'll lose 30% of its rating at Yellowstone on an 80 degree day.  This was why I moved from the Yamaha 2400 mentioned earlier to the Honda 3000.  Plus it has a larger fuel capacity.
Pilot View Drop Down
Direct Link To This Post Posted: 24 Aug 2015 at 8:57am
Hey Toolman,
Beautiful installation, you have way too much time on your hands!. Electrician in a previous life?
Walt & Lynne
2015 r-pod 177
08 F150 or 2014 Explorer
Pinckney,Mi
WillThrill View Drop Down
Direct Link To This Post Posted: 24 Aug 2015 at 11:24am
Out of curiosity, why did you not go with two Honda or Yamaha 2000 watt units and parallel them? The cost difference is not very much. Not only would you get more power, but if you didn't need to run the AC or microwave, you would only need to connect one.
I've actually seen people modify the parallel kits to enable them to run more than two units together as well as units of different wattage ratings.
2014 Hood River 177
2005 GMC Envoy XL
Direct Link To This Post Posted: 24 Aug 2015 at 8:02pm
Fuel capacity and sound rating.  My Yamaha always ran exactly 8 hours, which wasn't long enough.  Otherwise I was happy with it.  Since Yamahas don't have a fuel pump my choice was to switch to dual Hondas (with an external tank) or a larger Honda or Yamaha.  The Honda 3000 has the lowest sound rating, partly because its engine is oversized, so that swayed me.  I'm happy with the fuel tank size.  So far it has run my house over 22 hours w/o running out, and my Salem over 20 hours w/o running out.  An unintended benefit of the single unit is it is impossible for one person to steal, and nearly impossible for two.
Direct Link To This Post Posted: 24 Aug 2015 at 9:12pm
Where do you store your Honda 3000 when traveling?
Where do you keep it while running it?
Direct Link To This Post Posted: 25 Aug 2015 at 6:27am
Hey Toolman,
I have an old and little used Electronics Engineering degree, and 20+ years in manufacturing (tool and die making).
I purchased a hydraulic cable crimper to make the custom cable lengths so everything turned out perfect.
I also put the enclosure into a Bridgeport Mill in order to bore the through hole for the switch in the enclosure cover, and drill the mounting holes. All the mounting hardware is 18-8 stainless steel.
2013 VW Touareg TDI
Direct Link To This Post Posted: 25 Aug 2015 at 11:25am
http://www.rpod-owners.com/forum_posts.asp?TID=3689&PID=35302&title=my-generator-mount
