List Your Mods:
 Post Reply Post Reply Page  <1 3435363738 78>
rsgmd View Drop Down
Post Options Post Options   Quote rsgmd Quote  Post ReplyReply Direct Link To This Post Topic: List Your Mods:
    Posted: 17 Aug 2015 at 1:29am
Originally posted by bobditch
Originally posted by rsgmd
Thanks. The awning is a Carefree fiesta model with universal hardware arms. I had to cut the patio awning shorter to a total length of 7 feet 8 inches for it to fit. I also needed to install a new awning rail to accommodate the patio awning.
Can you explain the awning install in more detail, thanks.
A new regular awning rail needed to be attached by stainless crews and silicone sealant as the current one is curved and the size is too large. Once that was done, I took my awning arms and set them apart on the pod as far as possible without intruding into essential openings-- in this case the storage hatches. Shorter awning arms may have enabled me to get another few inches of awning width, but I did not have such hardware. Once the width of the arms were determined, I drilled holes to attach them to the pod. These holes accommodate 1/4" stainless bolts approximately 2.5 to 3.5" in length depending on the location. These definitely needed to be drilled through and attached with large flat washers and lock nuts. The holes were sealed with silicone around the bolts. For my hardware 4 bolts per attachment were needed (4 attachments in total). For the locations I picked, the upper attachment bolts will jut out of the inner wall by about 1/2 inch, but will be barely noticeable or may be covered up with some type of trim if one wishes. The lower attachments will have bolts that come out into the front and rear comparments. Once the arms are attached the total legth of the awning can be determined. Once measured, the awning can be cut with a metal oscillating blade or metal hacksaw to size. One must be careful of the springs in the awning as they are in tension. The tension should be carefully released per manufacturer instructions. Some awnings do not have springs and work with gears. These will be easier and safer to cut. Once the awning tube is resized, the awning material may be cut with a sharp blade or scissors. A half inch of hemming material should be left on to protect the edges from fraying and tearing. This extra awning cloth material can be folded in and stitched if desired. I used contact cement to keep the edge folded as I am not handy with needle and thread. Once the awning tube and cloth are put back together, it is just a matter of attaching the awning to the rail and securing the ends of the inserted bead with screws to prevent it from sliding out. The arms then attach to the awning ends. Done! It took me about 8 hours to finish, but I was trying to figure out the proper steps and how to cut the awning up along the way.
Post Options Post Options   Quote rsgmd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2015 at 1:05am
I have a teeny white dog in there when she wants to sleep undisturbed.
Post Options Post Options   Quote rsgmd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2015 at 1:03am
The hitch is a propride 3p. Really great hitch.
Tri-Pod View Drop Down
Post Options Post Options   Quote Tri-Pod Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2015 at 11:30pm
Wow those are some great modifications. What kind of criter do you keep in that cage?
2013 SP 240 w outside kitchen
5.7L V8
Me, My Honey, and Max our GSP
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2015 at 10:10pm
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2015 at 9:22pm
rsgmd - welcome.   What weight distribution hitch (WDH) is that?
Post Options Post Options   Quote Leo B Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2015 at 9:53pm
Really nice work!
Post Options Post Options   Quote rsgmd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2015 at 9:18pm
My pod is a 2015 178.
KrogPod View Drop Down
Post Options Post Options   Quote KrogPod Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2015 at 8:40pm
Rsgmd, Nice mods, they look great.
Tell us about the awning install. What model RPod is that.
Thanks
Paul
2014 RP-172, AKA KrogPod
2003 S10 ExCab V6 4.3L Automatic
Central Texas
