Page <12345> |
Author | |||
David and Danette ![]() podders Helping podders - pHp ![]() ![]() Joined: 24 Nov 2009 Online Status: Offline Posts: 1224 |
![]() Posted: 10 Aug 2015 at 8:10pm |
Ok I will order it from amazon.com. I had been thinking about it, you are most likely right. I thank you techntrek and furpod for your help this forum has been so helpful for myself and others.
I still would look into replacing the original start capacitor. If that is the problem it could continue to get worse until it won't start even with a 30 amp outlet.
Solved the problem of our AC my mother is moving and has a generator for us to use. She bought it when Hurricane Wilma hit south Florida and left her without electricity. It had been sitting for a long time but was able to get it running and it works the AC and microwave at the same time. It is a Dewalt DG4300 powered by a 8 hp. Honda engine. It's not the most quiet generator and heavy 150 lbs. but it will fit in the back of our truck with the tonneue cover closed and with the tail gate locked it will be secure when not in use. It will be nice to have in a rest area when it is hot like it was last two weeks when we were traveling. And for our house in TN I will install a 30 amp. outlet. I will not use it in a camp ground because of it being noisy and the camp grounds we stay at have 30 amp electrical hookups.
Yes. Capacitors are sized for the motor, not the model.
Has not hurt ours in 4 years.. from the description: "Applications: Room A/C units, Residential and commercial PSC A/C units and heat pumps, For all PSC A/C units from 4,000 thru 120,000 BTU's (1/2 thru 10 H.P.)" Don't take this wrong.. but all a/c units are pretty much exactly alike under the shroud. Really. |
The cap you need.. two wires to install. CAP. |
I have been thinking maybe I can do this myself. Is it that difficult, where could I buy the hard start capacitor, how do I know which one is correct for our AC ? The little I know about electricity it makes sense what you are saying and it wouldn't hurt and would be helpful if we ever wanted to use a generator.
Thank you, Techntrek. I have a friend in church who is retired from Carrier as a service tech. and he has a motor home. I will ask him in church today if he could look at it and install a hard start capacitor. I will look over his shoulder and ask questions and hopefully learn something about electricity.
Ultimately that is a band-aid. I would still add the 30 amp outlet, but it doesn't solve the sudden problem.
My next guess is the startup capacitor on your A/C has gone bad. That will shoot your startup amperage up. So a 30 amp outlet can still handle it while a 15 amp outlet can't. It shouldn't be bad so soon, but that doesn't mean it can't be bad. I would look at that next. Even add a hard-start capacitor.
Page <12345> |
