Page <1234> |
Pilot ![]() Groupie ![]() ![]() Joined: 26 Jul 2015 Location: Pinckney, Mi Online Status: Offline Posts: 91 |
![]() Posted: 27 Jul 2015 at 10:04pm |
Ended up placing an order for the Renogy 100 watt. We'll see!
sailor323 ![]() Senior Member ![]() Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
It depends on what your energy needs are. Given that the refrigeration can be run on propane, most of us have modest needs. LED lighting, a few small, inverter driven appliances, fans, radio, 100 to 130 watts would certainly cover it all. If you want to watch TV or keep your laptop turned on or want to run an icemaker, you might more. In sizing the system, you have got to take an inventory or your power needs. You should also remember that the rated output of a panel is based on ideal circumstances. |
No one has really addressed what watt is sufficient regardless of brand.
Is 80 okay? Too much, not enough? |
There are many suppliers of quality, name brand solar panels that cost much less than the Zamp panels. I think that Zamp buys panels that are available to anyone and then repackages them in kits for resale. You can probably get the same thing that Zamp sells for about half of Zamp's price. On the other hand, if you want "plug and play" and are willing to pay for it, Zamp fills the bill.
Thanks to both. I will be on hunting property with no electrical connection unless I have a generator. If we go to a campground it probably won't be a problem.
Seems in this sport you need to cover a lot of bases. |
How are you going to use your pod? how many, and what battery(ies) are you running? Zamp is not the least expensive.. doesn't make them a "ripoff" any more than a Mercedes is a ripoff. Can other cars get you from a to b for less money? yes. But that doesn't have jack to do with if you were ripped off or not buying it. |
Hayduke ![]() Groupie ![]() Joined: 03 Apr 2012 Location: Salt Lake, UT Online Status: Offline Posts: 68 |
Yeah I think they are very expensive for what they are. I've never heard anyone complain about their quality though. I bought a folding suitcase style 120w setup from solarblvd for way less than half of the zamp setup. same function. Solarblvd only carries them sporadically. Another cheaper option: Renogy Suitcase |
2012 177 HRE
2017 Tacoma Double Cab |
Hey Hayduke,
Why are they a rip? Price? Is there something cheaper? What do you use? |
CoastalCal ![]() Groupie ![]() ![]() Joined: 23 May 2015 Online Status: Offline Posts: 43 |
My Hubby uses the Pod when he goes to music festivals....no hookups....and loves the Zamp panels. They are effortless and work great....just be sure not to leave them unattended as the are pricey and could walk off!
2015 178 R-Pod
Ford F-250 4x4 Diesel 2014 Indian Vintage 2010 HD Ultra Classic |
Zamp is a ripoff IMO
2012 177 HRE
Page <1234> |
