  New Posts New Posts RSS Feed: ZAMP wiring
Topic ClosedZAMP wiring
shanebevel View Drop Down
Direct Link To This Post Topic: ZAMP wiring
    Posted: 16 Jul 2015 at 12:23pm
Yup, or a SAE to PowerPole pigtail and then I can power everything I already have with PowerPoles. Why more people don't use that connector, I don't know. They are just awesome.
Direct Link To This Post Posted: 16 Jul 2015 at 12:19pm
Originally posted by shanebevel
As a weird side note, the first thing I thought when I saw the port was power access! The plug used (while not the awesome Anderson Power Pole) is a standard connector, so a man could build a pigtail to whatever he wanted and access 12v from the back of the camper through a sizable cable. Ham radio/chargers/12v led lantern all kinds of stuff.
My only thought was that I didn't know if it ran through a converter of some type, but it looks like a direct connection, so that's pretty cool!
So in theory, any solar panel producing 12v+ could be used here right? Not just a zamp branded kit.
Shane
Yes you can add a SAE connector to any panel/controller combo and feed at that port.. and yes.. 12v goes both ways.. so you could add a properly wired SAE connector to anything 12v you wanted to power outside. Wink
Direct Link To This Post Posted: 15 Jul 2015 at 11:02pm
Shane
mikeyg2347 View Drop Down
Direct Link To This Post Posted: 08 Jul 2015 at 9:09pm
oooops, I mean total distance of 50'. 20' plus 30', uh, somebody help me here...I ran out of fingers and toes.
Mike
Direct Link To This Post Posted: 08 Jul 2015 at 9:08pm
Yep, I factored in the wire from the connector to the battery for a total distance of 20'. Should be OK with 10 gauge wire all the way from the charger to the battery.
Mike
Podster View Drop Down
Direct Link To This Post Posted: 08 Jul 2015 at 7:30pm
LOL, Good Deal...don't forget to add the original 20' or so if you are using the Zamp Plug!
Another acceptable practice if you don't know the amperage output of a panel, you can figure 1 amp for ever 15 watts of panel size. So a 50w panel is rated at about 3 amps out and a 100w panel at 6.
Since amperage increases power flow, distance will be shorter and/or wire size will be larger.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 08 Jul 2015 at 12:31pm
Ditto on the calculator!!
Direct Link To This Post Posted: 08 Jul 2015 at 10:22am
That calculator is really cool. Makes it easy for the rookie/amateur (me) to get a fast answer. Looks like if I use 10 gauge cable I can go about 35' from the Zamp port and keep the line loss to less than 3%. Solar chargers can be a challenge when you want the trailer in the shade, but the solar panel needs to be in the sun. Thanks for the link.
Mike
Direct Link To This Post Posted: 07 Jul 2015 at 9:34pm
This solar wire size calculator may help and has more info about some of the variables...
10g is a pretty good size tube, presumably done by FR and Zamp to mute any critics about the wire being
to small. I think FR and Zamp nailed it. There is no money to be saved where wire is used for power transmission. Smile
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 07 Jul 2015 at 6:01pm
There are a few variables, but stranded copper 10g wire will lose about .25 volts every 15 feet. Your controller may have an adjustable output, or automatic.
