Q7-retired
Topic: How cold does your fridge get? Posted: 13 Jul 2015 at 9:03am |
Folks, I completely agree with you. However, when the dealer says Dometic requires this as the diagnostic method, then I have the choice of working with it or thinking the dealer a liar. I am not going to have any trouble showing that the fridge does not hold temperature over a four to six hour drive, as time-stamped photos of the thermometer in the water bath will prove it.
In support of the method, it is true that absorption (compressor-less) refrigerators do not respond quickly to changes in external conditions, and air temperature will change rapidly. I also have a digital thermometer hanging in my fridge. Both the air and water thermometers will be in the pictures.
We'll just make sure easily perishable food is in an ice chest/ cooler, where it won't spoil, until this is settled. The next long trip is from NC to the MI UP -- does anyone know a GREAT dealer around East Jordan?
again, thanks!
Best regards, Jim
2015-RP178
TV 2015 Audi Q7 TDI and 2017 Ford F150
At home in "Our Pod"
Posted: 13 Jul 2015 at 7:55am |
Doug is exactly right. OH, and it's going to be a bit problematic to test a cup of water after it sits for a day in the freezer.. it will be frozen, unless there IS a problem with your fridge.. we track ours like so: This was on a 90F day, air conditioning on in the pod, interior temp around 72F, fridge on 120v.
Posted: 13 Jul 2015 at 12:12am |
Hate to say it but that is bull. I had a service manager try to tell me that last year. Fridges - of all types - cool the air, which then cool the contents. Any air temperature gauge will give you an accurate reading of how cool it is inside the fridge, and many many campers use the wireless thermometers to keep an eye on the fridge while going down the road. Reading the temperature of a cup of water gives you a delayed reading of how the fridge is operating - so it can be warming up and you'll think it is still cool (or think it is too warm when it really did cool down to 35 fairly quickly).
Q7-retired
Posted: 12 Jul 2015 at 6:13pm |
I'm struggling with propane operation, and learned that the dealer must measure fridge temp with a thermometer in water. Air warms quickly, water more slowly, so they take the temp with a water bath making it temporally stable. My fridge on electric easily gets to 37 degrees with outside temps in the 90's. I haven't measured the freezer compartment.
Best regards, Jim
2015-RP178
Posted: 11 Jul 2015 at 11:55pm |
We left the freezer compartment out of ours so it was all fridge, and we always measured around 35 F. Upper 30's in the fridge in our Salem with the freezer compartment down to 12 F. 104 outside on the way to camp today and when we pulled in the fridge was reading 38.
TigerPawd
Posted: 07 Jul 2015 at 1:32pm |
Hmm. Two defective Dometics in a row? Not impossible, I guess. We have had TTs with Dometic fridges for 25 years and this is the first little one - also the first to give us trouble.
It's definitely level. In the hot afternoon most days, the vent side is shaded. I have left the fridge on for a week at a time, with 48° being the very best on a cool morning. I can hear the little fan(s) running when it gets warm outside so I know they are working. We have resorted to taking along some freezer bags and alternating them from freezer to fridge section.
We keep an indoor-outdoor thermometer in the Pod with the remote inside the fridge, so we don't have to open the door to see what's happening. I have been chalking our problems up to the single door design, which is different from our previous bigger units.
Maybe I need to head back to the dealer. Thanks for the feedback.
Joan, Jerry and the two Pugs
2015 R-Pod 179
Podster
Posted: 06 Jul 2015 at 11:51pm |
I'm in San Antonio and usually run between 37 and 41 degrees. Initial cooling take 24-48 hours. Recovery is slow. Every time the door is opened, the temp goes up 1 degree. The ammonia absorption fridge has no moving parts and gravity plays a key roll making level operation critical when sitting still. To determine if the unit is level place a circular bubble lever inside the bottom shelf of the freezer. It doesn't have to be level when driving because the bouncing around ensures things keep flowing. Good ventilation is another key element. Some folks have reported better performance in the heat by removing the outside grills allowing more free air flow.
Cliff & Raelynn
Ranger 4.0/178
podenvy
Posted: 06 Jul 2015 at 4:51pm |
We camp regularly in near 100F dry heat and the fridge keeps bottles of liquid to the almost freezing point when cranked up.
We discovered plugging in the pod at least 24 hours before the trip and keeping the pod as level as possible really affects fridge performance. If you can't do 24 hours, then use the blue cooler blocks inside and that will help. We got leveling blocks for the wheels and a small level guide lives stuck to the area in front of the propane tank.
2013 FJ Cruiser + 2015 rpod 179 HRE
Leo B
Posted: 06 Jul 2015 at 1:46pm |
We did have a little trouble back when we had our 171 and was camping down in Florida when the temps were between 90-95 degrees. Seemed to never completely cool. Then all was find when we got back up north an outside temps were a lot cooler.
TigerPawd
Posted: 06 Jul 2015 at 9:37am |
Down here in south Texas, daytime temperatures are running 93° and more. The freezer does all right but we're lucky if we can get below 50° in the lower section in the afternoon. This is our second unit too. The original did about the same.
The Dometic fridge in our old FR Surveyor generally got at least 10-15° cooler when it's this hot.
2015 R-Pod 179
