  New Posts New Posts RSS Feed: n00b fridge question
Topic Closedn00b fridge question
JohnBG View Drop Down
Direct Link To This Post Topic: n00b fridge question
    Posted: 29 Jun 2015 at 12:21am
When towing the pod, should I be running the refrigerator on propane or DC power?  I was thinking propane but a friend who has an RV says that might be a bad idea.
2010 R-Pod RP-171
2010 Honda Ridgeline TV
mcclurey View Drop Down
Direct Link To This Post Posted: 29 Jun 2015 at 12:24am
I run DC because your tow vehicle should be charging the battery while driving if you have the proper 7 pin wiring set up. Why waste propane?
Missouri Matt
Direct Link To This Post Posted: 29 Jun 2015 at 12:32am
The battery I have is pretty weak.  Might need to run to Wally World and pick up a new one.
2010 R-Pod RP-171
Direct Link To This Post Posted: 29 Jun 2015 at 7:55am
Unless in an area where it is forbidden, (east coast tunnels, Canada) Feel free to run with propane if you want. It uses very little, and as much as the "sky is falling" people want you to believe they are, America's highways and byways are NOT littered with burned out RV hulks.
john in idaho View Drop Down
Direct Link To This Post Posted: 29 Jun 2015 at 11:17am
But remember to turn off the propane when you are refueling the tow vehicle.  Hate to loose the whole rig.
HuronSailor View Drop Down
Direct Link To This Post Posted: 29 Jun 2015 at 12:03pm
In my case propane does a better job of cooling, but DC is more convenient, so we usually use DC. It's adequate but not great.
Direct Link To This Post Posted: 29 Jun 2015 at 8:56pm
I always recommend propane.  The charge +12 line must be at least 10 gauge, preferably 8 gauge, in order to just barely keep up with the load of the fridge on DC mode.
Most installers install, and factory wiring is, 12 gauge.  It is cheaper and appears to do the job.  Add in the high amperage from the fridge (11 amps), long run to the rear bumper, 12 gauge on the camper side and that will drop the voltage to the point that the pod battery will support the load for a while and then drop to a low voltage itself.  Maybe 2 hours on the road and the air temp in the fridge will start to warm up.  If the pod battery is already low that will start right away - even if you do have 10 gauge wire.  8 gauge is barely adequate in that situation.
I've run the numbers here before.  15 foot run to the rear bumper, 11 amps, 12 gauge wire, 14 volts from the alternator, and you are at a 4.7% voltage drop.  It should be below 2% for DC runs.  10 gauge is just below 3%, 8 gauge is 1.9%.  Plus the wiring on the camper side is probably 12 gauge.  The run from the tongue back to the fridge is another length of wire not in this equation... add another 10 feet all at 12 gauge and you are at 7.8%!
Most larger RVs only have propane as an option on the road.  Propane tanks have flow-limiter valves which prevent a huge fire if a line is cut in an accident.  Finally forgetting to turn off the fridge at a gas station is no big deal.  Gasoline fumes have a very narrow flammability range (too much or too little gasoline and it won't light), it hugs the ground but the flame is 2-3 feet off the ground, and the fumes are diluted by the surrounding air especially if it is windy.
Camper Bob View Drop Down
Direct Link To This Post Posted: 30 Jun 2015 at 12:36am
Doug, you have convinced me.  After all these years towing and using the battery to keep the reefer cold, I finally switched over to propane while on the road.  With the purchase of the new Nissan Pathfinder, I did some sleuthing and found out that the charge line is indeed 12 gauge.  Have towed the last three trips with the propane on until we camp with a full hookup and then transfer to A/C.  You made me a believer.  Really just sips propane.  Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
Direct Link To This Post Posted: 30 Jun 2015 at 8:59am
That too, the pod fridge will go a month on one tank.  You could upgrade your wiring, even if you just run a parellel line of 12 gauge that will give you the equivelent of 10 gauge.  Or run a 10 gauge in parallel and you will be close to 8 gauge equivalent.  I ran another length of 12 so I'm close to 10 now, but I still use propane mode.
