  New Posts New Posts RSS Feed: Battery charging?
Topic ClosedBattery charging?
JohnBG View Drop Down
Direct Link To This Post Topic: Battery charging?
    Posted: 24 Jun 2015 at 6:52pm
Yeah I didn't think the interior meter was accurate, it was one light before and now it's 4.  I can take a meter out and check the voltage but the best way is to test the battery under load.  I'll probably end up in the battery section at the local Wally World soon... Cry
2010 R-Pod RP-171
2010 Honda Ridgeline TV
Direct Link To This Post Posted: 24 Jun 2015 at 9:57pm
The load test is good to find out how well it will hold up, but you won't do that test often.  The test at rest you'll do often to find the SOC.
WillThrill View Drop Down
Direct Link To This Post Posted: 26 Jun 2015 at 4:13pm
Originally posted by JohnBG
When the camper is plugged into 120VAC should it be charging the battery?  Or do I need to charge it with a separate charger?
 My battery is about completely dead as previous owner left it connected and it drained.
Or is it time for a new battery?
If a lead acid battery is completely or nearly drained and left that way for a few months, it is dead beyond any hope of reviving. After 'charging' such a battery, it might seem like it's okay because the voltage of the battery might be good, but it's capacity is almost completely gone.
Rather than plug up the unit periodically, I simply remove my batteries when we aren't using the Pod and place them on a Battery Minder #1500 all the time. It's temperature sensitive, so it doesn't matter that I leave them in my uninsulated garage. This way, I never have to worry whether my batteries are alright.
The other key to battery maintenance is checking the water level periodically, at the beginning and end of the camping season is good. The cells must be topped off with distilled water and nothing else.
2014 Hood River 177
2005 GMC Envoy XL
Direct Link To This Post Posted: 01 Jul 2015 at 11:23am
Ended up going to Wally World and picking up a new one for ~$80.  I'll make sure to disconnect it when storing the pod.
2010 R-Pod RP-171
