Page 123> |
Q7-retired ![]() Senior Member ![]() ![]() Joined: 26 Dec 2014 Location: Pittsboro, NC Online Status: Offline Posts: 100 |
![]() Posted: 17 Aug 2015 at 4:44pm |
Folks, an update. I've just completed a 4000 mile towing vacation, comprised 80% towing, 20% with Our-Pod not following behind. I averaged 42 mph and 18.0 mpg. I towed at 60 mph max, depending on speed limit. Actual towing mpg was 15-17 mpg.
Of course, this is for my particular TV. "Your mileage may vary!" |
Best regards, Jim
2015-RP178 TV 2015 Audi Q7 TDI and 2017 Ford F150 At home in "Our Pod" |
garbob ![]() Newbie ![]() Joined: 03 Dec 2013 Location: Canada Online Status: Offline Posts: 13 |
I have the WD hitch as well and can't imagine towing without it.
Markie ![]() Groupie ![]() ![]() Joined: 22 Sep 2013 Location: Chambersburg PA Online Status: Offline Posts: 67 |
I also tow a 178 with a 2013 Honda Pilot. As garbob mentioned the RPM is around 2500 at 60 MPH. I don't have a lot of towing experience but after returning from a trip of over 1000 miles I had mixed results. Initially I didn't have Weight distribution or sway control. I had a slight but noticeable amount of porpoising when the pavement had humps and dips. It would take a little time for the suspension to absorb the energy and stabilize.
Above 60 MPH sway became a concern. I could feel the effects of the sway and I would slow to make it stop. In cross wind it would be more noticeable. After installing and adjusting the WD hitch ( Fastway model E2) the porpoising was eliminated. The sway was greatly reduced but not eliminated. I did notice some sway when being passed by a tractor trailer but I felt like I had allot more control. I think I still have some adjusting necessary to tweak the WD to the Pilot. For safety purposes I don't feel comfortable towing above 60 to 65 MPH. I have talked to other podders that say they don't think there is a need for WD. They said, "The R-pod is so light there is no need". I feel the lighter the camper the more one should be concerned about sway. I can't imagine trying to tow long distances in heavy traffic without it. The difference is amazing. I would be interested in hearing others opinions and experiences forming their beliefs on the need (or not) for Weight Distribution. |
Mark & Vicki
R-POD 178 & 2015 Silverado 5.3L Weimeraner "Zeke" |
coopercdrkey ![]() podders Helping podders - pHp ![]() ![]() Joined: 26 Aug 2012 Location: Cedar Key, FL Online Status: Offline Posts: 457 |
Living (and camping) in Florida, we don't encounter the terrain variations that you do. I tend to drive by RPM's. Once up to speed (using the tow mode setting) I revert to normal operation mode and take whatever speed I get at 1500 RPM. This is usually 55 to 58 mph and is fine for the length of trips we take. Being passed by other motorists no longer threatens my man card....
Bob and Joyce
Jennifer and Baxter, the Campin' Cocker Spaniels RP 177 "Key Pod" Chevrolet Silverado 1500 LT / Z71 |
topher2u2 ![]() Newbie ![]() ![]() Joined: 12 Jul 2015 Location: Broomfield CO Online Status: Offline Posts: 18 |
The best towing experience we have is at low speeds climbing through the mountains. The trailer feels very planted and mpg's are good. Pulling on the interstate is another story and I agree that 60-65 is probably the best compromise. At 60 we are already feeling the mpg tax, but that speed gives the most options to take action.
#3PsnRPod
2016 R-Pod RP 171 2015 Jeep Grand Cherokee |
With a 2013 Honda Pilot pulling a 2013 178, around 2500 RPM seems to be the ticket.
Marx ![]() Senior Member ![]() Joined: 18 Jul 2014 Location: Charleston Online Status: Offline Posts: 103 |
I like 60 with both of my two towing rigs as well.
2014 R-POD 177
Going west in Wyoming along route 80 with 55 mph+ headwinds our best tow speed was whatever we could do!
Normally, however, we are in the majority of 60-65 unless there is an opportunity to pass a fifth wheel or Airstream. Then we step on it. fred
john in idaho ![]() Senior Member ![]() ![]() Joined: 04 Nov 2014 Location: Eagle Idaho Online Status: Offline Posts: 613 |
At 60 or 62, you never have to pass anyone. If your transmission has a tow-haul mode, be sure to use it. It changes the shift points, and makes the speed control a little less responsive so the engine won't rev so high when the speed drops off on a hill.
Page 123> |
