Calendar Event: Newbie with AC Outlet issues Posted: 22 Jun 2015 at 5:52pm |
You may have something else on that circuit.
JohnBG
Posted: 22 Jun 2015 at 2:38pm |
Originally posted by Jpntime
Just a quick note make sure you have your water heater off or have water in it so you don't burn it up My house only has 20 amp circuit I cannot run the AC from the house but it will charge the battery |
Actually most people are ok running their A/C from a 15 amp outlet at home since it uses about 1000 watts with the fan on low. Just don't try to run anything else high-wattage at the same time. |
I can run the air on low on mine for about 5 minutes until it trips the house breaker.
2010 R-Pod RP-171
2010 Honda Ridgeline TV
techqueen
Posted: 20 Jun 2015 at 9:32pm |
From one newbie to another...
1) When our Pod is plugged in at home using a 30 to 15 plug, the AC in the pod works just fine. We have used the pod as a cool place on really hot days since our house does not have AC. Best guest house ever!
2) The GFCI plug in our pod has two black buttons that are really hard to see due to their location in a dark, low corner. Our outlets were not working when plugged in to house power and it took me a while to realize that there were actually two buttons to press (as I knew there should be). I eventually figured out which button to press to reset the system and, voila, the outlets work fine.
3) Sometimes, plugging and unplugging the pod causes the system to trip so I have to reset it before everything works as expected.
4) One Honda 2000 generator will run the microwave/convection oven just fine...I used it for baking cinnamon rolls...yummm!
5) We went with a pair of Honda 2000 generators in case we ever plan to camp where we might need the AC (also works as back up at the house if needed). We went with generators over solar due to the issues of shade or cloud cover on the coast AND so we could run outlets, mic/conv oven and AC in addition to charging pod batteries.
6) I still don't get the whole inverter and 12v stuff...I want to be able to charge small electronics off th batteries but need to figure out what plugs to add and how to do this next.
Honda Pilot plus 176T for me ;0)
Posted: 21 May 2015 at 1:04pm |
Awesome! Just be sure to charge the battery overnight every 30 days and before/after each trip, if you don't leave it plugged in all the time. And if you do disconnect it between trips also disconnect the battery from the pod, or the LPG detector and the fridge electronics will kill it in a week or two.
CreaganCondo
Posted: 20 May 2015 at 10:15pm |
Well I'm happy to report that I do not have a dud. Cudos go out to Technetrek because I went back to the Pigtail adapter (NOT PUCK) an a different outlet from my house & BLAMOO!! a faint beep & the Pod came to life!! Outlets, TV, even lights on Microwave all came on & Battery reading full (which I understand to mean that the batteries are charging.) Food & adult beverages promptly loaded into frig for our (Now confident) excursion tomorrow & so happy that we figured it out the American way: NOT by reading instructions, NOT by taking it back to the dealer (which would have been more than a hassle) and NOT by giving up!! Trusting your new friends in the RPOD forum, some cursing, and a $6 Harbor Freight pigtail!!! Hoooraaaaaay
CreaganCondo
Posted: 20 May 2015 at 8:29pm |
Tried puck & pigtail adapters...
Posted: 20 May 2015 at 8:26pm |
Just want to be sure - did you get an adapter and plug the pod in at home?
CreaganCondo
Posted: 20 May 2015 at 10:31am |
Something is definitely not right. Battery won't charge & outlets have never worked. Taking into my dealer before camping outing this weekend. Will report back....
Luv2Q
Posted: 20 May 2015 at 10:04am |
I'm able to run our AC at home using a 15 amp outlet & extension cord. The Kil-A-Wat tells me, though, that voltage drops to ~108 when the compressor kicks on. Right at the edge of a brown-out if I'm interpreting correctly. I definitely don't turn on anything else (except the 12v lites) when the AC's on.
John & Teri
Tundra 5.7L V8 / RP 180
Posted: 20 May 2015 at 7:30am |
