List Your Mods: |
Page <1 4344454647 78> |
Cap-n-Cray ![]() Senior Member ![]() ![]() Joined: 22 Feb 2014 Location: Bainbridge Is Online Status: Offline Posts: 121 |
![]() ![]() ![]() ![]() Posted: 27 Mar 2015 at 9:39pm |
14 gauge is 15 AMPS, 12 gauge is 20 AMPS...
Cary
2014 RP-177 |
marspball ![]() Newbie ![]() Joined: 15 Jul 2014 Online Status: Offline Posts: 20 |
I was thinking about doing that. But I notice that the cable running to the back is only 14 gauge. will it be powerful enough to run the lights plus tv and charge phone? The tv is only about 3.5 amps, phone is 1-2amp and lights maybe another 1amp? If tapping the existing wire is safe, then that's a perfect solution for me.
Oops, I guess that would be helpful. Lol The socket/USB plug can be purchased on ebay for $10. http://www.ebay.com/itm/Dual-USB-Car-Cigarette-Lighter-Socket-Splitter-12V-Charger-Power-Adapter-Outlet-/381005422890 I placed it right by the door which is above the electric panel so running the cable to the panel was pretty easy. The outlet itself has 2 screw on rings which you're supposed to use to mount it securely to the wall. However, there was no access from the back so I had to figure out another way. So I made two holes with a drill and hole saw that is big enough so that the retaining ring will fit and the plastic cover will sit flush with the wall. for wiring, I used 12 gauge wire which i know it is an overkill but the price diff of 12ga compared to 14ga wasn't that much. it doesn't show in the picture but inside the wall, the cable from the panel is split into two and then hooked up to the outlets. The kit already comes with the cable connectors. To hook it up to the electric panel, you do have to remove it which is pretty easy. Just two screws for the cover and another 4 screws for the panel and it slides forward. All the negative cables are connected to a bar on the bottom left of the panel (on the floor) and the positive cable gets hooked up to the 12v panel. I then used a 15amp fuse and everything works like a charm. I then positioned the cover of the outlet, drilled pilot holes for the screws and voila. From start to finish, the whole installation only took about 30 min. I hope this helps. |
marspball, you may be able to find a 12 volt line run for lighting that you can tap, instead of running a new one.
fionasol ![]() Newbie ![]() ![]() Joined: 15 Oct 2014 Location: United States Online Status: Offline Posts: 13 |
Marspball,
Would you mind sharing the details of install?
My first mod on my 182G...
I installed this 12v socket / USB combo so I can use a 12v TV and charge my USB devices when dry camping. I want to install another one in the garage but pulling the cable from the garage to the panel seems to be a daunting task. |
apache ![]() Newbie ![]() Joined: 14 Mar 2015 Online Status: Offline Posts: 4 |
LePodders ![]() Groupie ![]() ![]() Joined: 20 Nov 2013 Location: Louisiana Online Status: Offline Posts: 80 |
Poddy by Nature |
Poddy by Nature |
securing cushions on 179 ![]() ![]() ![]() ![]() |
Poddy by Nature |
