  New Posts New Posts RSS Feed: Solar panel security
Topic ClosedSolar panel security
bearclaw68 View Drop Down
Direct Link To This Post Topic: Solar panel security
    Posted: 25 Jan 2015 at 12:58am
Any thoughts on keeping your portable zamp panels from getting stolen while charging? Or am I over thinking this? 600.00 sitting outside my pod worries me.
John and Dolly
09 Tacoma 4x4
RP 179
Direct Link To This Post Posted: 25 Jan 2015 at 1:01am
Also is 100W overkill or is bigger better? 100W portable panels are semi heavy.
John and Dolly
09 Tacoma 4x4
RP 179
Podster View Drop Down
Direct Link To This Post Posted: 25 Jan 2015 at 5:59am
I don't think so. During my years in the Security Forces and Law Enforcement the number one reported and documented crime was theft of property that was not secured. Sure, if a thief really wants something they can figure out a way, but securing property removes the easy, unplanned opportunity.
If I were using unmounted panels I would try to figure out a way to make them look mounted. I would probably use some kind of temp attachment on top of the POD. If going on top the POD is not an option, maybe attach a cable to the frame of the panel and loop it through something?
As far a sizing that all depends on use, but I don't think 100w is over the top at all.
Use this solar calculator (off-grid section) to determine use and solar sizing.
Good luck!
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 25 Jan 2015 at 4:35pm
Thank you.
John and Dolly
09 Tacoma 4x4
RP 179
Direct Link To This Post Posted: 25 Jan 2015 at 7:58pm
Yup, if you can't babysit them, secure them.
kylekai View Drop Down
Direct Link To This Post Posted: 26 Jan 2015 at 4:00pm
I used an old computer security cable with a lock.  This type of cable is long and skinny, with a loop at the end.  I wind the cable thru a section of the solar panel and secure the loop end at the trailer with a lock.  Search Amazon for "computer security cable" and you'll find something.
rickcosby View Drop Down
Direct Link To This Post Posted: 30 Jan 2015 at 4:35pm
I saw a security cable in a campground that must have been 25 - 30 feet.  It was on a reel and was designed to run through all of your outdoor furniture, ice chests, etc when you leave.
Direct Link To This Post Posted: 30 Jan 2015 at 4:44pm
Something like this cable and a good lock should do the trick:
http://www.amazon.com/Master-Lock-72DPF-Braided-Diameter/dp/B000BD8IQ4/ref=sr_1_5?ie=UTF8&qid=1422654158&sr=8-5&keywords=security+cable
CruiseMaster View Drop Down
Direct Link To This Post Posted: 23 May 2015 at 8:24pm
You can purchase the cable cut to any length you want at any good hardware store.
I have the Dish Tailgater that sits outside and is attached to the trailer with a cable. I also use a Doberman bag alert protector. This is a small alarm that is sensitive to movement. If someone attempts to move my Dish it goes off and it is loud. Here is the link to the alarm. http://www.homedepot.com/p/Doberman-Security-Bag-Protector-Alert-SE-0304/100657694?N=5yc1vZ45r
RP 179 - Peace Pod
2012 Dodge Grand Caravan
Being Retired is hard work.
