Page <123 |
JStrube ![]() Groupie ![]() Joined: 11 Aug 2014 Location: Atwater, CA Online Status: Offline Posts: 90 |
![]() Posted: 22 Jan 2015 at 11:21am |
Last time I needed a seal, I took mine off & went to the local trailer dealer, the one that does farm trailers. They had them, cheap. They can do a cross ref by looking at your part #.
2012 181G
Podster ![]() Senior Member ![]() ![]() Joined: 16 Sep 2014 Location: San Antonio Online Status: Offline Posts: 1108 |
EDIT: This Description from LIPPERT does not match yours: Lippert
Parts OK Thanks. Sure would like to upgrade that "should" to "will" I'm looking for the absolute correct part. If the seals leak, grease contaminates the brakes. Does anyone here on the forum service and repack their POD wheel bearings? Amazon has them, but...the description doesn't say anything about double lip. Is this the correct seal? Does anybody know who manufactures the seals? Is it AP? Does anybody know for sure...are the AP seals used by Lippert? AP
Products |
Cliff & Raelynn
Seanl ![]() Senior Member ![]() ![]() Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
That grease seal is a double lip 1.69 inside diameter and 5.565 Outside diameter grease seal. As long as the replacement met those specs you should be good.
Are the part numbers the same in the auto parts stores...I don't want to "eye ball" this one.
Cliff & Raelynn
Craneman ![]() Senior Member ![]() Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
Most auto part stores have replacement seals as well as RV repair shops
Moe
Jo and Gary 2010 174 2011 Ford 150 |
I have the Lippert Axle and it calls for grease seal Part # 122087 and Lippert direct wants $11.00+ to ship a 2.00+ Part. (They don't use USPS)
Does any body have a better source? Can you find them locally? |
Cliff & Raelynn
Page <123 |
