campingnut
Topic: smoke detector Posted: 17 Dec 2014 at 3:12pm |
Our smoke detector started beeping. Opened the detector and found no 9V battery. Put in a new battery. Still keeps beeping. Any fixes?
Al & Kathy
R-Pod 177
'98 Toyota 4Runner
Posted: 17 Dec 2014 at 3:19pm |
It isn't the smoke detector. My bet is your battery is low for the pod, and it's the propane detector.
campingnut
Posted: 17 Dec 2014 at 3:54pm |
It is the smoke detector beeping. Thanks, just reposted this question under maintenance tips.
Al & Kathy
R-Pod 177
'98 Toyota 4Runner
Posted: 17 Dec 2014 at 6:58pm |
If there was no battery it wasn't beeping. I agree with Furpod. I had the same trouble when we first got ours.
2011 R-Pod 177
2010 Ford F-150
hogone
Posted: 17 Dec 2014 at 9:04pm |
i'm going to slightly (just a little!!!) disagree hear. a smoke detector can beep for a period of time even after removing the battery. but i agree, i don't think this is the problem as campingnut mentioned it did not even have a battery in it to begin with. hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Posted: 18 Dec 2014 at 8:33am |
You have 3 detectors in the pod, smoke, carbon monoxide, and propane. Propane is the only one that is hardwired, and usually when people think they have a beeping smoke detector, they actually have a beeping propane detector because it "alarms" at about 11.5v for some reason. I have never had a smoke detector or cO detector that gave more than 1 or two beeps after the battery was removed.
The smoke detector can be removed by giving it a counter clockwise twist. Remove it from the pod, take it in the house. If it's still beeping, with a new battery in it, replace it. The pod is a very small space and it's often very hard to tell where a beep might be coming from.
Posted: 18 Dec 2014 at 9:44am |
Since this thread is in the wrong location, but the OP already started an identical thread in the correct location, let's move the discussion there...
