Forum Home Forum Home > General Camping > Cook'n With Gas > Pressure cookers
  New Posts New Posts RSS Feed: smoke detector
Topic Closedsmoke detector
Direct Link To This Post Topic: smoke detector
    Posted: 18 Dec 2014 at 9:44am
Since this thread is in the wrong location, but the OP already started an identical thread in the correct location, let's move the discussion there...
Direct Link To This Post Posted: 18 Dec 2014 at 8:33am
You have 3 detectors in the pod, smoke, carbon monoxide, and propane. Propane is the only one that is hardwired, and usually when people think they have a beeping smoke detector, they actually have a beeping propane detector because it "alarms" at about 11.5v for some reason. I have never had a smoke detector or cO detector that gave more than 1 or two beeps after the battery was removed.
The smoke detector can be removed by giving it a counter clockwise twist. Remove it from the pod, take it in the house. If it's still beeping, with a new battery in it, replace it. The pod is a very small space and it's often very hard to tell where a beep might be coming from.
hogone View Drop Down
Direct Link To This Post Posted: 17 Dec 2014 at 9:04pm
i'm going to slightly (just a little!!!) disagree hear.  a smoke detector can beep for a period of time even after removing the battery.  but i agree, i don't think this is the problem as campingnut mentioned it did not even have a battery in it to begin with.  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 17 Dec 2014 at 6:58pm
If there was no battery it wasn't  beeping.  I agree with Furpod.  I had the same trouble when we first got ours.
2011 R-Pod 177
2010 Ford F-150
campingnut View Drop Down
Direct Link To This Post Posted: 17 Dec 2014 at 3:54pm
It is the smoke detector beeping. Thanks, just reposted this question under maintenance tips.
Al & Kathy
R-Pod 177
'98 Toyota 4Runner
Direct Link To This Post Posted: 17 Dec 2014 at 3:19pm
It isn't the smoke detector. My bet is your battery is low for the pod, and it's the propane detector.
Direct Link To This Post Posted: 17 Dec 2014 at 3:12pm
Our smoke detector started beeping. Opened the detector and found no 9V battery. Put in a new battery. Still keeps beeping. Any fixes?
Al & Kathy
R-Pod 177
'98 Toyota 4Runner
