  New Posts New Posts RSS Feed: Rear Stabilizers
Topic ClosedRear Stabilizers
RoyToy View Drop Down
Direct Link To This Post Topic: Rear Stabilizers
    Posted: 22 Jul 2017 at 7:42pm
We just had a WDH (Fastway e2 hitch trunnion style) installed on our 2011 Honda Pilot and 2015 179 pod. They had to use a longer shank in order to get the ball down far enough to level it out with the pod. But the clearance between the bottom of the WDH and ground is low and concerns us. I am guessing this is why folks have used the lift kits. Can someone tell us what kits you used and did you install them and how high did it lift the trailer?
Thanks
Podster View Drop Down
Direct Link To This Post Posted: 05 Dec 2014 at 8:37pm
Clever and solid solution to the rear jack clearance problem. Thanks for sharing this.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 05 Dec 2014 at 7:32pm
I like.
coledj View Drop Down
Direct Link To This Post Posted: 05 Dec 2014 at 5:17pm
3/4in angle 2 pices 1/4 flat steel total size about 4 1/2 in. use an angle grinder with cutoff wheel to narrow the top of jack so it will slide into the pocket. don't forget to put the jacks away when you tear down. these work great for me Dennis
Direct Link To This Post Posted: 05 Dec 2014 at 5:12pm
I am not good at posting photos if this wont open PM me and I will send to your email or phone Thanks
Direct Link To This Post Posted: 04 Dec 2014 at 8:18pm
Good deal...Smile
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 04 Dec 2014 at 8:04pm
will try and post tomorrow
Direct Link To This Post Posted: 04 Dec 2014 at 7:54pm
Originally posted by coledj
I removed my rear jacks and welded a slide pocket. works great
Got Pics???
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 04 Dec 2014 at 6:19pm
Seanl View Drop Down
Direct Link To This Post Posted: 24 Nov 2014 at 10:35am
Originally posted by cody91
I have an Rpod 178 and I had to remove the rear stabilizers because they were hitting the ground when I would try to leave my driveway.  I've been using the Camco aluminum stack jacks as a solution but I've been searching for other solutions that may be more convenient.
I recently say this RV Stabilizer in Camping World and I was wondering if anyone had any experience with using it on an RPOD?  Both good and bad.
http://www.campingworld.com/shopping/item/universal-rv-stabilizer/34337
Thanks,
Cody
I see the min frame height for these is 14 inches. I don't know if you have that much in a Pod.
